Hello everybody,
atm I’m in the middle of migrating from an ESXi host to an Proxmox Host, want to utilize containers and so on. So what I did, was to update to 2.0.0p8 CFE, make a full backup on the old system. There was it a VM. On the new system, I created a Debian 10 container, installed 2.0.0p8, restored from the full backup. After installing the agent on the Container, I still have CPU Util - unkown
Can sobody help me maybe figuring out whats going on?
Thanks in advance!
Cheers,
Gamie
rprengel
(Ralf Prengel)
August 2, 2021, 5:47am
2
did you update from a version 1.6.x to 2.0.8?
Ralf
Heyho,
no, I updated from 2.0.0p6 to 2.0.0p8 and the CPU Util worked on the old server
hi. i need your plugins or script about Counter strike server status. I need that. please help me
Hello again everyone,
so after updating to p18 it’s still not possible to see the CPU Util Can anyone help me with that?
<<<check_mk>>>
Version: 2.0.0p18
AgentOS: linux
Hostname: cssourceclassic
AgentDirectory: /etc/check_mk
DataDirectory: /var/lib/check_mk_agent
SpoolDirectory: /var/lib/check_mk_agent/spool
PluginsDirectory: /usr/lib/check_mk_agent/plugins
LocalDirectory: /usr/lib/check_mk_agent/local
<<<labels:sep(0)>>>
{"cmk/device_type":"container"}
<<<df>>>
/dev/mapper/bigdata-vm--111--disk--0 ext4 6102624 3563580 2208088 62% /
none tmpfs 492 4 488 1% /dev
tmpfs tmpfs 16163152 0 16163152 0% /dev/shm
tmpfs tmpfs 16163152 8268 16154884 1% /run
tmpfs tmpfs 5120 0 5120 0% /run/lock
tmpfs tmpfs 3232628 0 3232628 0% /run/user/1000
<<<df>>>
[df_inodes_start]
/dev/mapper/bigdata-vm--111--disk--0 ext4 393216 28652 364564 8% /
none tmpfs 4040788 23 4040765 1% /dev
tmpfs tmpfs 4040788 1 4040787 1% /dev/shm
tmpfs tmpfs 4040788 103 4040685 1% /run
tmpfs tmpfs 4040788 2 4040786 1% /run/lock
tmpfs tmpfs 4040788 4 4040784 1% /run/user/1000
[df_inodes_end]
<<<systemd_units>>>
[list-unit-files]
UNIT FILE STATE
proc-sys-fs-binfmt_misc.automount static
dev-hugepages.mount static
dev-mqueue.mount static
proc-sys-fs-binfmt_misc.mount static
sys-fs-fuse-connections.mount static
sys-kernel-config.mount masked
sys-kernel-debug.mount masked
systemd-ask-password-console.path static
systemd-ask-password-wall.path static
session-3371.scope transient
apt-daily-upgrade.service static
apt-daily.service static
autovt@.service disabled
bootlogd.service masked
bootlogs.service masked
bootmisc.service masked
check_mk-async.service enabled
check_mk@.service static
checkfs.service masked
checkroot-bootclean.service masked
checkroot.service masked
console-getty.service enabled-runtime
container-getty@.service indirect
cron.service enabled
cryptdisks-early.service masked
cryptdisks.service masked
dbus-org.freedesktop.hostname1.service static
dbus-org.freedesktop.locale1.service static
dbus-org.freedesktop.login1.service static
dbus-org.freedesktop.timedate1.service static
dbus-org.freedesktop.timesync1.service enabled
dbus.service static
debug-shell.service disabled
emergency.service static
fstrim.service static
getty-static.service static
getty@.service disabled
halt.service masked
hostname.service masked
hwclock.service masked
ifup@.service static
ifupdown-pre.service static
ifupdown-wait-online.service disabled
initrd-cleanup.service static
initrd-parse-etc.service static
initrd-switch-root.service static
initrd-udevadm-cleanup-db.service static
killprocs.service masked
kmod-static-nodes.service static
kmod.service static
logrotate.service static
man-db.service static
module-init-tools.service static
motd.service masked
mountall-bootclean.service masked
mountall.service masked
mountdevsubfs.service masked
mountkernfs.service masked
mountnfs-bootclean.service masked
mountnfs.service masked
networking.service enabled
postfix.service enabled
postfix@.service indirect
procps.service static
quotaon.service static
rc-local.service static
rc.local.service static
rc.service masked
rcS.service masked
reboot.service masked
rescue.service static
rmnologin.service masked
rsyslog.service enabled
screen-cleanup.service masked
sendsigs.service masked
serial-getty@.service disabled
single.service masked
ssh.service enabled
ssh@.service static
sshd.service enabled
stop-bootlogd-single.service masked
stop-bootlogd.service masked
sudo.service masked
system-update-cleanup.service static
systemd-ask-password-console.service static
systemd-ask-password-wall.service static
systemd-backlight@.service static
systemd-binfmt.service static
systemd-bless-boot.service static
systemd-boot-check-no-failures.service disabled
systemd-exit.service static
systemd-fsck-root.service static
systemd-fsck@.service static
systemd-fsckd.service static
systemd-halt.service static
systemd-hibernate-resume@.service static
systemd-hibernate.service static
systemd-hostnamed.service static
systemd-hwdb-update.service static
systemd-hybrid-sleep.service static
systemd-initctl.service static
systemd-journal-flush.service static
systemd-journald.service static
systemd-kexec.service static
systemd-localed.service static
systemd-logind.service static
systemd-machine-id-commit.service static
systemd-modules-load.service static
systemd-networkd-wait-online.service disabled
systemd-networkd.service disabled
systemd-poweroff.service static
systemd-quotacheck.service static
systemd-random-seed.service static
systemd-reboot.service static
systemd-remount-fs.service static
systemd-resolved.service disabled
systemd-rfkill.service static
systemd-suspend-then-hibernate.service static
systemd-suspend.service static
systemd-sysctl.service static
systemd-sysusers.service static
systemd-time-wait-sync.service disabled
systemd-timedated.service static
systemd-timesyncd.service enabled
systemd-tmpfiles-clean.service static
systemd-tmpfiles-setup-dev.service static
systemd-tmpfiles-setup.service static
systemd-udev-settle.service static
systemd-udev-trigger.service static
systemd-udevd.service static
systemd-update-utmp-runlevel.service static
systemd-update-utmp.service static
systemd-user-sessions.service static
systemd-volatile-root.service static
udev.service static
umountfs.service masked
umountnfs.service masked
umountroot.service masked
urandom.service static
user-runtime-dir@.service static
user@.service static
x11-common.service masked
machine.slice static
user.slice static
check_mk.socket enabled
dbus.socket static
ssh.socket disabled
syslog.socket static
systemd-fsckd.socket static
systemd-initctl.socket static
systemd-journald-audit.socket masked
systemd-journald-dev-log.socket static
systemd-journald.socket static
systemd-networkd.socket disabled
systemd-rfkill.socket static
systemd-udevd-control.socket static
systemd-udevd-kernel.socket static
basic.target static
bluetooth.target static
boot-complete.target static
cryptsetup-pre.target static
cryptsetup.target static
ctrl-alt-del.target disabled
default.target static
emergency.target static
exit.target disabled
final.target static
getty-pre.target static
getty.target static
graphical.target static
halt.target disabled
hibernate.target static
hybrid-sleep.target static
initrd-fs.target static
initrd-root-device.target static
initrd-root-fs.target static
initrd-switch-root.target static
initrd.target static
kexec.target disabled
local-fs-pre.target static
local-fs.target static
multi-user.target static
network-online.target static
network-pre.target static
network.target static
nss-lookup.target static
nss-user-lookup.target static
paths.target static
poweroff.target disabled
printer.target static
reboot.target disabled
remote-cryptsetup.target disabled
remote-fs-pre.target static
remote-fs.target enabled
rescue-ssh.target static
rescue.target static
rpcbind.target static
runlevel0.target disabled
runlevel1.target static
runlevel2.target static
runlevel3.target static
runlevel4.target static
runlevel5.target static
runlevel6.target disabled
shutdown.target static
sigpwr.target static
sleep.target static
slices.target static
smartcard.target static
sockets.target static
sound.target static
suspend-then-hibernate.target static
suspend.target static
swap.target static
sysinit.target static
system-update-pre.target static
system-update.target static
time-sync.target static
timers.target static
umount.target static
apt-daily-upgrade.timer enabled
apt-daily.timer enabled
fstrim.timer disabled
logrotate.timer enabled
man-db.timer enabled
systemd-tmpfiles-clean.timer static
227 unit files listed.
[all]
UNIT LOAD ACTIVE SUB DESCRIPTION
proc-sys-fs-binfmt_misc.automount loaded inactive dead Arbitrary Executable File Formats File System Automount Point
-.mount loaded active mounted /
dev-full.mount loaded active mounted /dev/full
dev-hugepages.mount loaded inactive dead Huge Pages File System
dev-mqueue.mount loaded active mounted POSIX Message Queue File System
dev-null.mount loaded active mounted /dev/null
dev-ptmx.mount loaded active mounted /dev/ptmx
dev-random.mount loaded active mounted /dev/random
dev-tty.mount loaded active mounted /dev/tty
dev-tty1.mount loaded active mounted /dev/tty1
dev-tty2.mount loaded active mounted /dev/tty2
dev-urandom.mount loaded active mounted /dev/urandom
dev-zero.mount loaded active mounted /dev/zero
proc-cpuinfo.mount loaded active mounted /proc/cpuinfo
proc-diskstats.mount loaded active mounted /proc/diskstats
proc-loadavg.mount loaded active mounted /proc/loadavg
proc-meminfo.mount loaded active mounted /proc/meminfo
proc-stat.mount loaded active mounted /proc/stat
proc-swaps.mount loaded active mounted /proc/swaps
proc-sys-fs-binfmt_misc.mount loaded inactive dead Arbitrary Executable File Formats File System
proc-sys-kernel-random-boot_id.mount loaded active mounted /proc/sys/kernel/random/boot_id
proc-sys-net.mount loaded active mounted /proc/sys/net
proc-sysrq\x2dtrigger.mount loaded active mounted /proc/sysrq-trigger
proc-uptime.mount loaded active mounted /proc/uptime
run-user-1000.mount loaded active mounted /run/user/1000
sys-devices-system-cpu-online.mount loaded active mounted /sys/devices/system/cpu/online
sys-devices-virtual-net.mount loaded active mounted /sys/devices/virtual/net
sys-fs-fuse-connections.mount loaded active mounted FUSE Control File System
â— sys-kernel-config.mount masked inactive dead sys-kernel-config.mount
â— sys-kernel-debug.mount masked inactive dead sys-kernel-debug.mount
â— tmp.mount not-found inactive dead tmp.mount
systemd-ask-password-console.path loaded active waiting Dispatch Password Requests to Console Directory Watch
systemd-ask-password-wall.path loaded active waiting Forward Password Requests to Wall Directory Watch
init.scope loaded active running System and Service Manager
session-3371.scope loaded active running Session 3371 of user w2tj
â— apparmor.service not-found inactive dead apparmor.service
apt-daily-upgrade.service loaded inactive dead Daily apt upgrade and clean activities
apt-daily.service loaded inactive dead Daily apt download activities
â— auditd.service not-found inactive dead auditd.service
check_mk-async.service loaded active running Checkmk agent - Asynchronous background tasks
â— connman.service not-found inactive dead connman.service
console-getty.service loaded active running Console Getty
container-getty@1.service loaded active running Container Getty on /dev/tty1
container-getty@2.service loaded active running Container Getty on /dev/tty2
cron.service loaded active running Regular background program processing daemon
dbus.service loaded active running D-Bus System Message Bus
â— display-manager.service not-found inactive dead display-manager.service
emergency.service loaded inactive dead Emergency Shell
â— exim4.service not-found inactive dead exim4.service
getty-static.service loaded inactive dead getty on tty2-tty6 if dbus and logind are not available
ifupdown-pre.service loaded active exited Helper to synchronize boot up for ifupdown
kmod-static-nodes.service loaded inactive dead Create list of required static device nodes for the current kernel
logrotate.service loaded inactive dead Rotate log files
man-db.service loaded inactive dead Daily man-db regeneration
networking.service loaded active exited Raise network interfaces
â— NetworkManager.service not-found inactive dead NetworkManager.service
â— plymouth-quit-wait.service not-found inactive dead plymouth-quit-wait.service
â— plymouth-start.service not-found inactive dead plymouth-start.service
postfix.service loaded active exited Postfix Mail Transport Agent
postfix@-.service loaded active running Postfix Mail Transport Agent (instance -)
rc-local.service loaded inactive dead /etc/rc.local Compatibility
rescue.service loaded inactive dead Rescue Shell
rsyslog.service loaded active running System Logging Service
â— sendmail.service not-found inactive dead sendmail.service
ssh.service loaded active running OpenBSD Secure Shell server
systemd-ask-password-console.service loaded inactive dead Dispatch Password Requests to Console
systemd-ask-password-wall.service loaded inactive dead Forward Password Requests to Wall
systemd-binfmt.service loaded inactive dead Set Up Additional Binary Formats
systemd-fsck-root.service loaded inactive dead File System Check on Root Device
systemd-fsckd.service loaded inactive dead File System Check Daemon to report status
systemd-hwdb-update.service loaded inactive dead Rebuild Hardware Database
systemd-initctl.service loaded inactive dead initctl Compatibility Daemon
systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running Login Service
systemd-machine-id-commit.service loaded inactive dead Commit a transient machine-id on disk
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-networkd.service loaded inactive dead Network Service
systemd-random-seed.service loaded inactive dead Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-sysusers.service loaded active exited Create System Users
systemd-timesyncd.service loaded inactive dead Network Time Synchronization
systemd-tmpfiles-clean.service loaded inactive dead Cleanup of Temporary Directories
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories
systemd-udev-trigger.service loaded inactive dead udev Coldplug all Devices
systemd-udevd.service loaded inactive dead udev Kernel Device Manager
â— systemd-update-done.service not-found inactive dead systemd-update-done.service
systemd-update-utmp-runlevel.service loaded inactive dead Update UTMP about System Runlevel Changes
systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown
systemd-user-sessions.service loaded active exited Permit User Sessions
â— systemd-vconsole-setup.service not-found inactive dead systemd-vconsole-setup.service
user-runtime-dir@1000.service loaded active exited User Runtime Directory /run/user/1000
user@1000.service loaded active running User Manager for UID 1000
-.slice loaded active active Root Slice
system-check_mk.slice loaded active active system-check_mk.slice
system-container\x2dgetty.slice loaded active active system-container\x2dgetty.slice
system-postfix.slice loaded active active system-postfix.slice
system.slice loaded active active System Slice
user-1000.slice loaded active active User Slice of UID 1000
user.slice loaded active active User and Session Slice
check_mk.socket loaded active listening Check_MK Agent Socket
dbus.socket loaded active running D-Bus System Message Bus Socket
syslog.socket loaded active running Syslog Socket
systemd-fsckd.socket loaded inactive dead fsck to fsckd communication Socket
systemd-initctl.socket loaded active listening initctl Compatibility Named Pipe
â— systemd-journald-audit.socket masked inactive dead systemd-journald-audit.socket
systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/log)
systemd-journald.socket loaded active running Journal Socket
systemd-udevd-control.socket loaded inactive dead udev Control Socket
systemd-udevd-kernel.socket loaded inactive dead udev Kernel Socket
basic.target loaded active active Basic System
cryptsetup.target loaded active active Local Encrypted Volumes
emergency.target loaded inactive dead Emergency Mode
getty-pre.target loaded inactive dead Login Prompts (Pre)
getty.target loaded active active Login Prompts
graphical.target loaded active active Graphical Interface
local-fs-pre.target loaded active active Local File Systems (Pre)
local-fs.target loaded active active Local File Systems
multi-user.target loaded active active Multi-User System
network-online.target loaded active active Network is Online
network-pre.target loaded inactive dead Network (Pre)
network.target loaded active active Network
nss-lookup.target loaded inactive dead Host and Network Name Lookups
nss-user-lookup.target loaded inactive dead User and Group Name Lookups
paths.target loaded active active Paths
remote-fs-pre.target loaded inactive dead Remote File Systems (Pre)
remote-fs.target loaded active active Remote File Systems
rescue.target loaded inactive dead Rescue Mode
shutdown.target loaded inactive dead Shutdown
slices.target loaded active active Slices
sockets.target loaded active active Sockets
swap.target loaded active active Swap
sysinit.target loaded active active System Initialization
time-sync.target loaded active active System Time Synchronized
timers.target loaded active active Timers
umount.target loaded inactive dead Unmount All Filesystems
apt-daily-upgrade.timer loaded active waiting Daily apt upgrade and clean activities
apt-daily.timer loaded active waiting Daily apt download activities
logrotate.timer loaded active waiting Daily rotation of log files
man-db.timer loaded active waiting Daily man-db regeneration
systemd-tmpfiles-clean.timer loaded active waiting Daily Cleanup of Temporary Directories
<<<nfsmounts>>>
<<<cifsmounts>>>
<<<mounts>>>
/dev/mapper/bigdata-vm--111--disk--0 / ext4 rw,relatime,stripe=256 0 0
<<<ps_lnx>>>
[header] CGROUP USER VSZ RSS TIME ELAPSED PID COMMAND
0::/init.scope root 30124 10292 00:00:02 00:00 1 /sbin/init
0::/system.slice/systemd-journald.service root 27572 10944 00:00:00 00:00 46 /lib/systemd/systemd-journald
0::/system.slice/dbus.service messagebus 9056 4488 00:00:00 00:00 68 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
0::/system.slice/check_mk-async.service root 6332 4000 00:00:00 00:00 69 /bin/bash /usr/bin/check_mk_agent
0::/system.slice/rsyslog.service root 156192 3568 00:00:00 00:00 70 /usr/sbin/rsyslogd -n -iNONE
0::/system.slice/systemd-logind.service root 19396 7312 00:00:00 00:00 71 /lib/systemd/systemd-logind
0::/system.slice/cron.service root 5516 2272 00:00:00 00:00 72 /usr/sbin/cron -f
0::/system.slice/system-container\x2dgetty.slice/container-getty@2.service root 2424 1668 00:00:00 00:00 116 /sbin/agetty -o -p -- \u --noclear --keep-baud tty2 115200,38400,9600 linux
0::/system.slice/console-getty.service root 2424 1672 00:00:00 00:00 117 /sbin/agetty -o -p -- \u --noclear --keep-baud console 115200,38400,9600 linux
0::/system.slice/system-container\x2dgetty.slice/container-getty@1.service root 2424 1668 00:00:00 00:00 118 /sbin/agetty -o -p -- \u --noclear --keep-baud tty1 115200,38400,9600 linux
0::/system.slice/ssh.service root 15856 6684 00:00:00 00:00 119 /usr/sbin/sshd -D
0::/system.slice/system-postfix.slice/postfix@-.service root 43476 4892 00:00:00 00:00 311 /usr/lib/postfix/sbin/master -w
0::/system.slice/system-postfix.slice/postfix@-.service postfix 43824 8124 00:00:00 00:00 313 pickup -l -t unix -u -c
0::/system.slice/system-postfix.slice/postfix@-.service postfix 43876 8032 00:00:00 00:00 314 qmgr -l -t unix -u
0::/user.slice/user-1000.slice/session-3371.scope root 16636 7900 00:00:00 00:00 764 sshd: w2tj [priv]
0::/user.slice/user-1000.slice/user@1000.service/init.scope w2tj 21032 8664 00:00:00 00:00 881 /lib/systemd/systemd --user
0::/user.slice/user-1000.slice/user@1000.service/init.scope w2tj 31368 3420 00:00:00 00:00 882 (sd-pam)
0::/user.slice/user-1000.slice/session-3371.scope w2tj 16920 5856 00:00:00 00:00 890 sshd: w2tj@pts/3
0::/user.slice/user-1000.slice/session-3371.scope w2tj 4920 4316 00:00:00 00:00 891 -bash
0::/system.slice/check_mk-async.service root 4052 752 00:00:00 00:00 1203 sleep 60
0::/user.slice/user-1000.slice/session-3371.scope w2tj 6332 3840 00:00:00 00:00 1204 /bin/bash /usr/bin/check_mk_agent
0::/user.slice/user-1000.slice/session-3371.scope w2tj 6332 3324 00:00:00 00:00 1217 /bin/bash /usr/bin/check_mk_agent
0::/user.slice/user-1000.slice/session-3371.scope w2tj 6332 2364 00:00:00 00:00 1218 /bin/bash /usr/bin/check_mk_agent
0::/user.slice/user-1000.slice/session-3371.scope w2tj 4196 752 00:00:00 00:00 1219 cat
0::/user.slice/user-1000.slice/session-3371.scope w2tj 6332 2672 00:00:00 00:00 1243 /bin/bash /usr/bin/check_mk_agent
0::/user.slice/user-1000.slice/session-3371.scope w2tj 9400 3048 00:00:00 00:00 1244 ps ax -o cgroup:512,user:32,vsz,rss,cputime,etime,pid,command --columns 10000
0::/user.slice/user-1000.slice/session-3371.scope w2tj 4080 752 00:00:00 00:00 1245 tr -s
<<<mem>>>
MemTotal: 524288 kB
MemFree: 418216 kB
MemAvailable: 494732 kB
Buffers: 0 kB
Cached: 76516 kB
SwapCached: 0 kB
Active: 38080 kB
Inactive: 56260 kB
Active(anon): 128 kB
Inactive(anon): 25968 kB
Active(file): 37952 kB
Inactive(file): 30292 kB
Unevictable: 0 kB
Mlocked: 80032 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 17824 kB
Mapped: 0 kB
Shmem: 8272 kB
KReclaimable: 177480 kB
Slab: 0 kB
SReclaimable: 0 kB
SUnreclaim: 0 kB
KernelStack: 10860 kB
PageTables: 28808 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 17998156 kB
Percpu: 42304 kB
HardwareCorrupted: 0 kB
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
DirectMap4k: 2501900 kB
DirectMap2M: 20011008 kB
DirectMap1G: 12582912 kB
<<<lxc_container_cpu>>>
cpu 139484 0 50490 7596946 28116 0 519 0 90067 0
num_cpus 1
<<<uptime>>>
376.32 376.32
<<<lnx_if>>>
[start_iplink]
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0@if132: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 32:f1:a8:22:87:7c brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.0.7.111/21 brd 10.0.7.255 scope global eth0
inet6 fe80::30f1:a8ff:fe22:877c/64 scope link
[end_iplink]
<<<lnx_if:sep(58)>>>
lo: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
eth0: 44152 630 0 0 0 0 0 0 249945 538 0 0 0 0 0 0
[lo]
Address: 00:00:00:00:00:00
[eth0]
Speed: 10000Mb/s
Address: 32:f1:a8:22:87:7c
<<<lnx_bonding:sep(58)>>>
<<<tcp_conn_stats>>>
01 1
06 1
0A 5
<<<diskstat>>>
1642154511
8 0 sda 790443 87359 94248343 312247 901382 4556850 99394355 187986 0 1372136 500234 0 0 0 0 0 0
8 16 sdb 58726 9804 9920479 498317 1355107 263095 26158465 8075515 0 5784112 8573832 0 0 0 0 0 0
8 17 sdb1 28 0 1088 82 0 0 0 0 0 144 82 0 0 0 0 0 0
8 18 sdb2 167 6 17467 619 1 0 1 0 0 748 620 0 0 0 0 0 0
8 19 sdb3 58418 9798 9893570 497313 1355106 263095 26158464 8075514 0 5783704 8572828 0 0 0 0 0 0
253 0 dm-0 108 0 6496 896 0 0 0 0 0 704 896 0 0 0 0 0 0
253 1 dm-1 13344 0 803418 269532 153259 0 3723056 14088112 0 4557820 14357644 0 0 0 0 0 0
8 48 sdd 57539 1 14699385 66305 14 1 120 891 0 82560 67196 0 0 0 0 0 0
8 49 sdd1 57472 1 14696840 65658 14 1 120 891 0 81896 66549 0 0 0 0 0 0
253 2 dm-2 521 0 4248 5860 864 0 6912 115896 0 13620 121756 0 0 0 0 0 0
253 3 dm-3 22267 0 916466 247248 1463554 0 22427400 12315012 0 938004 12562260 0 0 0 0 0 0
253 4 dm-4 22267 0 916466 247296 1463554 0 22427400 12317872 0 938008 12565168 0 0 0 0 0 0
253 5 dm-5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
253 7 dm-7 317664 0 1365641 22692 174559 0 9501764 5804 0 247772 28496 0 0 0 0 0 0
253 6 dm-6 28233 0 1228506 138980 35506 0 2569040 4656 0 89208 143636 0 0 0 0 0 0
253 8 dm-8 3389 0 418106 6560 921 0 105096 136 0 3456 6696 0 0 0 0 0 0
253 9 dm-9 4013 0 507154 8872 669 0 106504 44 0 3952 8916 0 0 0 0 0 0
253 11 dm-11 3193 0 193402 3888 670 0 8504 32 0 2964 3920 0 0 0 0 0 0
253 10 dm-10 2703 0 141698 2380 390 0 5840 8 0 2108 2388 0 0 0 0 0 0
253 12 dm-12 16029 0 706946 10032 3333 0 129720 476 0 10888 10508 0 0 0 0 0 0
253 14 dm-14 2407 0 138274 876 344 0 5472 4 0 1424 880 0 0 0 0 0 0
253 13 dm-13 2693 0 143130 3172 506 0 6768 0 0 2188 3172 0 0 0 0 0 0
<<<md>>>
Personalities :
unused devices: <none>
<<<vbox_guest>>>
<<<job>>>
<<<local:sep(0)>>>
The problem here is the data from the Proxmox container. Actual Proxmox containers are using cgroupv2 and the CheckMK agent cannot handle this correctly at the moment.
There is already a longer discussion here.
Hi folks!
On my CMK RAW Installation (2.0.0p7), I’m monitoring multiple Docker nodes, 2 of them are Debian 11, Kernel 5.10, Docker 20.10.7, Python 3.9, python3-docker 4.1.0. The agent Plugin is delivering more data and other keys in the JSON dict, than on the older Docker nodes.
This leads to the following issue on container level running on the newer machine:
[grafik]
The mk_docker agent on Debian 11 produces following output:
<<<docker_container_mem:sep(0):cached(1626459022,90)>>>
@docke…
system
(system)
Closed
January 14, 2023, 11:38am
7
