Automatic page reload for Dashbaord
Hi, I would like to change the default value for the dashboard reload frequency to some other value for all dashboard. Is there a config option for that?
For most dashboards I can change the reload rate under Display → Customize View. But the “main dashboard” does not have a “Customize View” option. Is there another way to change the reload rate just for this dashboard?
You have to do this in the elements of the dashboard. That works at least for the elements based on views, not user about things like the globes.
You find a gear symbol in the right lower corner to open edit mode.
regards
Michael
