Hitachi VSP G series Monitoring
Is there any solution for this kind of Hitachi VSP G series storage?
I’m looking for the E series but I found this here for G series… hope this help, not working for me on E series…
Checkmk active check for Hitachi SVP
Tested on models x, x but according to API should work with VSP G130 G/F350
G/F370 G/F700 G/F900
Regards
Just an FYI that SVP PF-REST is not supported on the HM850 F/Gxx0 (e.g. G350/700/900) series
REST-API queries must be to the controllers directly
Only the R900/5x00 series supports SVP PF-REST, meaning REST-API queries fired directly at the Windows management platform that you access Storage Navigator and/or perform maintenance through
Just because something ‘works’ or responds to a query doesnt mean its supported, your mileage may vary :slight_smile:
