SNMPv3 discovers device, but throws this error.
Starting job...
SNMP scan failed: Cannot fetch system description OID .1.3.6.1.2.1.1.1.0. Please check your SNMP configuration. Possible reason might be: Wrong credentials, wrong SNMP version, Firewall rules, etc.
Completed.
This was too long to list, but here are some interesting screenshots
Checkmk version 2.0.0p11
Trying to acquire lock on /omd/sites/BWI/var/check_mk/license_usage/next_run
Got lock on /omd/sites/BWI/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/BWI/var/check_mk/license_usage/history.json
Got lock on /omd/sites/BWI/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/BWI/var/check_mk/license_usage/history.json
Released lock on /omd/sites/BWI/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/BWI/var/check_mk/license_usage/next_run
Released lock on /omd/sites/BWI/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/BWI/var/check_mk/autochecks/ZOSBWIUCSFI-A.mk
+ FETCHING DATA
[cpu_tracking] Start [7fb732ae84c0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/BWI/tmp/check_mk/data_source_cache/snmp/ZOSBWIUCSFI-A'), max_age=MaxAge(checking=0, discovery=1
20, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 316 sec, allowed is 0 sec)
No persisted sections loaded
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Executing SNMP GET of .1.3.6.1.2.1.1.1.0 on ZOSBWIUCSFI-A
=> [b'Cisco NX-OS(tm) ucs, Software (ucs-6400-k9-system), Version 9.3(5)I42(1b), RELEASE SOFTWARE Copyright (c) 2002-2021 by Cisco Systems, Inc. Compiled 6/24/2021 0:00:00'] OCTETSTR
Getting OID .1.3.6.1.2.1.1.2.0: Executing SNMP GET of .1.3.6.1.2.1.1.2.0 on <redacted>
=> [b'.1.3.6.1.4.1.9.12.3.1.3.2340'] OBJECTID
Using cached OID .1.3.6.1.2.1.1.1.0: 'Cisco NX-OS(tm) ucs, Software (ucs-6400-k9-system), Version 9.3(5)I42(1b), RELEASE SOFTWARE Copyright (c) 2002-2021 by Cisco Systems, Inc
In your first screenshots you see that SNMPv2 is working and v3 not. I think the first discovery was done with v2 enabled and that’s the reason why you see the services but get no information now after switching to v3.
What i not see from your other posts - is this a RAW edition or enterprise?
If you use the enterprise i would test to switch the SNMP backend for this one host to the classic one. I had already some devices that had problems with the Python backend and where working without problem with the classic one. This was especially with SNMPv3 the case.
Ok, I made that change, and I get the following in connection tests
It is green for snmpv1/v2 but those aren’t configured. V3 is complaining about the password being too short, but it’s working, see second picture
