Hello together,
I fixxed the Telegram Notification Script for the new Check MK Version:
thanks to mk@mathias-kettner.de and Stefan Gehn stefan+cmk@srcxbox.net for providing the initial script.
#!/usr/bin/env python3
# Telegram cmk2.0
import os, re, sys
from urllib.request import urlopen
import urllib.parse
import ssl
import urllib.request
ctx = ssl.create_default_context()
ctx.check_hostname = False
ctx.verify_mode = ssl.CERT_NONE
def fetch_notification_context():
context = {}
for (var, value) in os.environ.items():
if var.startswith("NOTIFY_"):
context[var[7:]] = value
return context
tmpl_host_text = """*Check_MK: $HOSTNAME$ - $EVENT_TXT$*
Host: $HOSTNAME$
Alias: $HOSTALIAS$
Address: $HOSTADDRESS$
Event: $EVENT_TXT$
Output: $HOSTOUTPUT$
$LONGHOSTOUTPUT$```"""
tmpl_service_text = """*Check_MK: $HOSTNAME$/$SERVICEDESC$ $EVENT_TXT$*
Host: $HOSTNAME$
Alias: $HOSTALIAS$
Service: $SERVICEDESC$
Event: $EVENT_TXT$
Output: $SERVICEOUTPUT$
$LONGSERVICEOUTPUT$```"""
def substitute_context(template, context):
# First replace all known variables
for varname, value in context.items():
template = template.replace('$'+varname+'$', value)
# Remove the rest of the variables and make them empty
template = re.sub("\$[A-Z_][A-Z_0-9]*\$", "", template)
return template
def construct_message_text(context):
notification_type = context["NOTIFICATIONTYPE"]
if notification_type in [ "PROBLEM", "RECOVERY" ]:
txt_info = "$PREVIOUS@HARDSHORTSTATE$ -> $@SHORTSTATE$"
elif notification_type.startswith("FLAP"):
if "START" in notification_type:
txt_info = "Started Flapping"
else:
txt_info = "Stopped Flapping ($@SHORTSTATE$)"
elif notification_type.startswith("DOWNTIME"):
what = notification_type[8:].title()
txt_info = "Downtime " + what + " ($@SHORTSTATE$)"
elif notification_type == "ACKNOWLEDGEMENT":
txt_info = "Acknowledged ($@SHORTSTATE$)"
elif notification_type == "CUSTOM":
txt_info = "Custom Notification ($@SHORTSTATE$)"
else:
txt_info = notification_type # Should neven happen
txt_info = substitute_context(txt_info.replace("@", context["WHAT"]), context)
context["EVENT_TXT"] = txt_info
if context['WHAT'] == 'HOST':
tmpl_text = tmpl_host_text
else:
tmpl_text = tmpl_service_text
return substitute_context(tmpl_text, context)
def send_telegram_message(token, chat_id, text):
url = 'https://api.telegram.org/bot%s/sendMessage' % (token)
data = urllib.parse.urlencode({'chat_id':chat_id, 'text':text, 'parse_mode':'Markdown'}).encode("utf-8")
urlopen(url, data=data, context=ctx).read()
#### CHANGE THESE ####
tg_token = '00000:XXXXXXXXXXXXXXXXXXXXXXXXX'
chat_id = '0000000'
context = fetch_notification_context()
text = construct_message_text(context)
send_telegram_message(tg_token, chat_id, text)
Just put it in ~/local/share/check_mk/notifications/
and configure it in the GUI.
Hope it helps you
