the detection of the network interface speed with “if64” seems to be broken:
Speed: 1.41 GBit/s (expected: 10 GBit/s)
I noticed this with SNMP checks on TrueNAS and Ubiquiti switches.
Check_MK version: 2.0.0p4 (CRE)
Is there a known bug?
hm in my environment Cisco, HP, Juniper SW it works as expected
it looks like that the used speed will be shown there
The used speed is 10GBits (shown in the Unifi Controller and TrueNAS interface). Also a speedtest shows the full 10GBits.
how it looks if you made the detection on the CLI ??
cmk -Ivv --checks=if64 YourSwitch
WebUI still shows 1.41 GBits.
OMD[<REMOVED>]:~$ cmk -Ivv --checks=if64 fs1
WARNING: '--checks' is deprecated in favour of option 'detect-plugins'
Discovering services and host labels on: fs1
fs1:
+ FETCHING DATA
[cpu_tracking] Start [7f6607c698e0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/fs1'), max_age=0, disabled=False, use_outdated=False, simulation=False), Cache enabled: False
if64: Fetching data (SNMP walk cache is disabled)
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.1'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.2'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.3'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.8'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.6'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.7'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.8'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.9'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.13'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.14'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.10'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.11'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.12'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.13'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.19'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.20'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.21'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.18'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.6'
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.15'
if64adm: Fetching data (SNMP walk cache is disabled)
Running 'snmpbulkwalk -Cr10 -v2c -c <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.7'
Write data to cache file /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/fs1
Try aquire lock on /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/fs1
Got lock on /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/fs1
Releasing lock on /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/fs1
Released lock on /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/fs1
[cpu_tracking] Stop [7f6607c698e0 - Snapshot(process=posix.times_result(user=0.030000000000000027, system=0.010000000000000009, children_user=0.02, children_system=0.02, elapsed=0.10000000149011612))]
[cpu_tracking] Start [7f6607296370]
No piggyback files for 'fs1'. Skip processing.
No piggyback files for '10.20.1.19'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/piggyback/fs1'), max_age=0, disabled=False, use_outdated=False, simulation=False), Cache enabled: False
Not writing data to cache file (Cache usage disabled)
[cpu_tracking] Stop [7f6607296370 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
Try aquire lock on /omd/sites/<REMOVED>/var/check_mk/persisted_sections/snmp/fs1
Got lock on /omd/sites/<REMOVED>/var/check_mk/persisted_sections/snmp/fs1
Releasing lock on /omd/sites/<REMOVED>/var/check_mk/persisted_sections/snmp/fs1
Released lock on /omd/sites/<REMOVED>/var/check_mk/persisted_sections/snmp/fs1
Stored persisted sections: if64, if64adm, hr_cpu, hr_fs, hr_mem, hr_ps, if, inv_if, snmp_info, snmp_os, snmp_uptime
Skipping persisted section SectionName('if64'), live data available
Skipping persisted section SectionName('if64adm'), live data available
Using persisted section SectionName('hr_cpu')
Using persisted section SectionName('hr_fs')
Using persisted section SectionName('hr_mem')
Using persisted section SectionName('hr_ps')
Using persisted section SectionName('if')
Using persisted section SectionName('inv_if')
Using persisted section SectionName('snmp_info')
Using persisted section SectionName('snmp_os')
Using persisted section SectionName('snmp_uptime')
-> Add sections: ['hr_cpu', 'hr_fs', 'hr_mem', 'hr_ps', 'if', 'if64', 'if64adm', 'inv_if', 'snmp_info', 'snmp_os', 'snmp_uptime']
Loading autochecks from /omd/sites/<REMOVED>/var/check_mk/autochecks/fs1.mk
No persisted sections loaded
-> Add sections: []
Received no piggyback data
+ EXECUTING HOST LABEL DISCOVERY
Trying host label discovery with: if64, hr_cpu, hr_fs, hr_mem, hr_ps, if64adm, inv_if, snmp_info, snmp_os, snmp_uptime
+ PERFORM HOST LABEL DISCOVERY
+ EXECUTING DISCOVERY PLUGINS (1)
Trying discovery with: if64
Try aquire lock on /omd/sites/<REMOVED>/var/check_mk/autochecks/fs1.mk
Got lock on /omd/sites/<REMOVED>/var/check_mk/autochecks/fs1.mk
Releasing lock on /omd/sites/<REMOVED>/var/check_mk/autochecks/fs1.mk
Released lock on /omd/sites/<REMOVED>/var/check_mk/autochecks/fs1.mk
SUCCESS - Found no new services, no new host labels
ifconfig
on the server shows media: Ethernet 10Gbase-T <full-duplex>
so the link is definately correct.
When you try to get data by SNMP-V1, the speed will shown in this way. Please user V2 to get the 64bit counter values. Then, the speed will shown correctly.
Cheers,
Christian
I have selected “SNMP v2 or v3” and used a SNMP community so this should be SNMP v2.
Edit: Switched to SNMPv3 on TrueNAS. Problem still exists.
Problem still exists with SNMPv2 and v3 in checkmk 2.0.0p5
Then it is a broken SNMP stack on your NAS.
If you do an “cmk --debug -vvn hostname” you see all the SNMP OIDs it fetches.
Can you provide this output?
This is from TrueNAS:
Checkmk version 2.0.0p5
Try aquire lock on /omd/sites/<REMOVED>/var/check_mk/license_usage/next_run
Got lock on /omd/sites/<REMOVED>/var/check_mk/license_usage/next_run
Try aquire lock on /omd/sites/<REMOVED>/var/check_mk/license_usage/history.json
Got lock on /omd/sites/<REMOVED>/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/<REMOVED>/var/check_mk/license_usage/history.json
Released lock on /omd/sites/<REMOVED>/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/<REMOVED>/var/check_mk/license_usage/next_run
Released lock on /omd/sites/<REMOVED>/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7efd04282a90]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/fs1'), max_age=0, disabled=False, use_outdated=False, simulation=False), Cache enabled: True
Not using cache (Too old. Age is 36 sec, allowed is 0 sec)
Persisted section hr_cpu is outdated by 1 seconds. Skipping it.
Persisted section hr_fs is outdated by 1 seconds. Skipping it.
Persisted section hr_mem is outdated by 1 seconds. Skipping it.
Persisted section if64 is outdated by 1 seconds. Skipping it.
Persisted section snmp_info is outdated by 1 seconds. Skipping it.
Persisted section snmp_uptime is outdated by 1 seconds. Skipping it.
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -On -OQ -Oe -Ot 10.20.1.19 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["TrueNAS-12.0-U3.1 (3544b04319). Hardware: amd64 Intel(R) Xeon(R) CPU E5-2643 v3 @ 3.40GHz running at 3396 MHz. Software: FreeBSD 12.2-RELEASE-p6 (revision 199506)"]
b'TrueNAS-12.0-U3.1 (3544b04319). Hardware: amd64 Intel(R) Xeon(R) CPU E5-2643 v3 @ 3.40GHz running at 3396 MHz. Software: FreeBSD 12.2-RELEASE-p6 (revision 199506)'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -On -OQ -Oe -Ot 10.20.1.19 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.50536.3.1]
b'.1.3.6.1.4.1.50536.3.1'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.50536.3.1'
Using cached OID .1.3.6.1.2.1.1.1.0: 'TrueNAS-12.0-U3.1 (3544b04319). Hardware: amd64 Intel(R) Xeon(R) CPU E5-2643 v3 @ 3.40GHz running at 3396 MHz. Software: FreeBSD 12.2-RELEASE-p6 (revision 199506)'
SNMP scan found hr_mem snmp_uptime
Try aquire lock on /omd/sites/<REMOVED>/tmp/check_mk/snmp_scan_cache/fs1.10.20.1.19
Got lock on /omd/sites/<REMOVED>/tmp/check_mk/snmp_scan_cache/fs1.10.20.1.19
Releasing lock on /omd/sites/<REMOVED>/tmp/check_mk/snmp_scan_cache/fs1.10.20.1.19
Released lock on /omd/sites/<REMOVED>/tmp/check_mk/snmp_scan_cache/fs1.10.20.1.19
hr_cpu: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.25.3.3.1.2'
hr_fs: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.25.2.3.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.25.2.3.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.25.2.3.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.25.2.3.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.25.2.3.1.6'
hr_mem: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.2
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.3
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.4
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.5
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.6
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.8'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.7'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.8'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.9'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.13'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.14'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.10'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.11'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.12'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.13'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.19'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.20'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.21'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.18'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.2.2.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.31.1.1.1.15'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -Cc -OQ -OU -On -Ot 10.20.1.19 .1.3.6.1.2.1.25.1.1'
[cpu_tracking] Stop [7efd04282a90 - Snapshot(process=posix.times_result(user=0.050000000000000044, system=0.03, children_user=0.76, children_system=0.04, elapsed=0.8999999985098839))]
[cpu_tracking] Start [7efd039855b0]
[cpu_tracking] Stop [7efd039855b0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7efd04282250]
Stored persisted sections: hr_cpu, hr_fs, hr_mem, if64, snmp_info, snmp_uptime
Skipping persisted section SectionName('hr_cpu'), live data available
Skipping persisted section SectionName('hr_fs'), live data available
Skipping persisted section SectionName('hr_mem'), live data available
Skipping persisted section SectionName('snmp_info'), live data available
Skipping persisted section SectionName('snmp_uptime'), live data available
-> Add sections: ['hr_cpu', 'hr_fs', 'hr_mem', 'if64', 'snmp_info', 'snmp_uptime']
-> Add sections: []
Loading item states
Try aquire lock on /omd/sites/<REMOVED>/tmp/check_mk/counters/fs1
Got lock on /omd/sites/<REMOVED>/tmp/check_mk/counters/fs1
Releasing lock on /omd/sites/<REMOVED>/tmp/check_mk/counters/fs1
Released lock on /omd/sites/<REMOVED>/tmp/check_mk/counters/fs1
CPU utilization Total CPU: 1.75%
<REMOVED>
Interface 1 [vtnet0], (up), MAC: <REMOVED>:50, Speed: 1.41 GBit/s (expected: 10 GBit/s)(!), In: 1.67 kB/s (<0.01%), Out: 1.35 kB/s (<0.01%)
Interface 2 [vtnet1], (up), MAC: <REMOVED>:51, Speed: 1.41 GBit/s (expected: 10 GBit/s)(!), In: 1.84 kB/s (<0.01%), Out: 80.8 kB/s (0.05%)
Interface 3 [vtnet2], (up), MAC: <REMOVED>:52, Speed: 1.41 GBit/s (expected: 10 GBit/s)(!), In: 23.6 B/s (<0.01%), Out: 0.00 B/s (0%)
Interface 4 [vtnet3], (up), MAC: <REMOVED>:53, Speed: 1.41 GBit/s (expected: 10 GBit/s)(!), In: 29.7 B/s (<0.01%), Out: 0.00 B/s (0%)
Memory used Total (RAM + Swap): 46.94% - 11.2 GiB of 24.0 GiB RAM, RAM: 46.94% - 11.2 GiB of 24.0 GiB, Swap: 0% - 0 B of 2.00 GiB
SNMP Info <REMOVED> unknown@localhost
Uptime Up since May 18 2021 15:38:02, Uptime: 8 days 5 hours
[cpu_tracking] Stop [7efd04282250 - Snapshot(process=posix.times_result(user=0.019999999999999796, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
[snmp] Success, execution time 0.9 sec | execution_time=0.920 user_time=0.070 system_time=0.030 children_user_time=0.760 children_system_time=0.040 cmk_time_snmp=0.020 cmk_time_agent=0.000
Switch (UniFi Aggregation):
Loading autochecks from /omd/sites/<REMOVED>/var/check_mk/autochecks/<REMOVED>.mk
+ FETCHING DATA
[cpu_tracking] Start [7f713341a0a0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/<REMOVED>'), max_age=0, disabled=False, use_outdated=False, simulation=False), Cache enabled: True
Not using cache (Too old. Age is 97 sec, allowed is 0 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -On -OQ -Oe -Ot 10.20.1.45 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Linux UBNT 3.18.24 #0 Thu Aug 30 12:10:54 2018 mips"]
b'Linux UBNT 3.18.24 #0 Thu Aug 30 12:10:54 2018 mips'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v3 -l authPriv -a sha -u <REMOVED> -A <REMOVED> -x AES -X <REMOVED> -m "" -M "" -On -OQ -Oe -Ot 10.20.1.45 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.8072.3.2.10]
b'.1.3.6.1.4.1.8072.3.2.10'
Using cached OID .1.3.6.1.2.1.1.1.0: 'Linux UBNT 3.18.24 #0 Thu Aug 30 12:10:54 2018 mips'
SNMP scan found snmp_uptime
Try aquire lock on /omd/sites/<REMOVED>/tmp/check_mk/snmp_scan_cache/<REMOVED>.10.20.1.45
Got lock on /omd/sites/<REMOVED>/tmp/check_mk/snmp_scan_cache/<REMOVED>.10.20.1.45
Releasing lock on /omd/sites/<REMOVED>/tmp/check_mk/snmp_scan_cache/<REMOVED>.10.20.1.45
Released lock on /omd/sites/<REMOVED>/tmp/check_mk/snmp_scan_cache/<REMOVED>.10.20.1.45
Write data to cache file /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/<REMOVED>
Try aquire lock on /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/<REMOVED>
Got lock on /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/<REMOVED>
Releasing lock on /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/<REMOVED>
Released lock on /omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/snmp/checking/<REMOVED>
[cpu_tracking] Stop [7f713341a0a0 - Snapshot(process=posix.times_result(user=0.020000000000000018, system=0.0, children_user=0.04, children_system=0.0, elapsed=0.08999999985098839))]
[cpu_tracking] Start [7f71333e7bb0]
No piggyback files for '<REMOVED>'. Skip processing.
No piggyback files for '10.20.1.45'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/<REMOVED>/tmp/check_mk/data_source_cache/piggyback/<REMOVED>'), max_age=0, disabled=False, use_outdated=False, simulation=False), Cache enabled: False
[cpu_tracking] Stop [7f71333e7bb0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f7133c9fe20]
Try aquire lock on /omd/sites/<REMOVED>/var/check_mk/persisted_sections/snmp/<REMOVED>
Got lock on /omd/sites/<REMOVED>/var/check_mk/persisted_sections/snmp/<REMOVED>
Releasing lock on /omd/sites/<REMOVED>/var/check_mk/persisted_sections/snmp/<REMOVED>
Released lock on /omd/sites/<REMOVED>/var/check_mk/persisted_sections/snmp/<REMOVED>
Stored persisted sections: ucd_cpu_load, ucd_cpu_util, if64, snmp_info, snmp_uptime
Using persisted section SectionName('ucd_cpu_load')
Using persisted section SectionName('ucd_cpu_util')
Using persisted section SectionName('if64')
-> Add sections: ['if64', 'snmp_info', 'snmp_uptime', 'ucd_cpu_load', 'ucd_cpu_util']
-> Add sections: []
Loading item states
Try aquire lock on /omd/sites/<REMOVED>/tmp/check_mk/counters/<REMOVED>
Got lock on /omd/sites/<REMOVED>/tmp/check_mk/counters/<REMOVED>
Releasing lock on /omd/sites/<REMOVED>/tmp/check_mk/counters/<REMOVED>
Released lock on /omd/sites/<REMOVED>/tmp/check_mk/counters/<REMOVED>
CPU load 15 min load: 0.73
CPU utilization PEND - Too short time difference since last check
Interface 1 [<REMOVED>], (up), MAC: <REMOVED>, Speed: 1.41 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 2 [<REMOVED>], (up), MAC: <REMOVED>, Speed: 1 GBit/s (expected: 1.41 GBit/s)(!), In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 3 [<REMOVED>], (up), MAC: <REMOVED>, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 4 [<REMOVED>], (up), MAC: <REMOVED>, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 5 [<REMOVED>], (up), MAC: <REMOVED>, Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 7 [<REMOVED>], (up), MAC: <REMOVED>, Speed: 1.41 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 8 [<REMOVED>], (up), MAC: <REMOVED>, Speed: 1.41 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
SNMP Info <REMOVED>
Uptime Up since May 14 2021 12:24:49, Uptime: 12 days 8 hours
[cpu_tracking] Stop [7f7133c9fe20 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
[snmp] Success, execution time 0.1 sec | execution_time=0.110 user_time=0.030 system_time=0.000 children_user_time=0.040 children_system_time=0.000 cmk_time_snmp=0.030 cmk_time_agent=0.000
If you run this snmpwalk manually what is the output for booth of your systems?
You can compare the result with this snmpwalk. The later one is the 32 bit speed value and the first one the speed value for 64 bit counters.
These are the results:
TrueNAS:
.1.3.6.1.2.1.31.1.1.1.15.1 = 1410
.1.3.6.1.2.1.31.1.1.1.15.2 = 1410
.1.3.6.1.2.1.31.1.1.1.15.3 = 1410
.1.3.6.1.2.1.31.1.1.1.15.4 = 1410
.1.3.6.1.2.1.31.1.1.1.15.5 = 0
.1.3.6.1.2.1.31.1.1.1.15.6 = 0
.1.3.6.1.2.1.2.2.1.5.1 = 1410065408
.1.3.6.1.2.1.2.2.1.5.2 = 1410065408
.1.3.6.1.2.1.2.2.1.5.3 = 1410065408
.1.3.6.1.2.1.2.2.1.5.4 = 1410065408
.1.3.6.1.2.1.2.2.1.5.5 = 0
.1.3.6.1.2.1.2.2.1.5.6 = 0
Switch:
.1.3.6.1.2.1.31.1.1.1.15.2 = 1000
.1.3.6.1.2.1.31.1.1.1.15.3 = 1000
.1.3.6.1.2.1.31.1.1.1.15.4 = 1000
.1.3.6.1.2.1.31.1.1.1.15.5 = 1000
.1.3.6.1.2.1.31.1.1.1.15.7 = 1410
.1.3.6.1.2.1.31.1.1.1.15.8 = 1410
.1.3.6.1.2.1.2.2.1.5.2 = 1000000000
.1.3.6.1.2.1.2.2.1.5.3 = 1000000000
.1.3.6.1.2.1.2.2.1.5.4 = 1000000000
.1.3.6.1.2.1.2.2.1.5.5 = 1000000000
.1.3.6.1.2.1.2.2.1.5.7 = 1410065408
.1.3.6.1.2.1.2.2.1.5.8 = 1410065408
You see booth devices report the wrong speed → broken SNMP Stacks on these devices.
need to show
.1.3.6.1.2.1.31.1.1.1.15.1 = 10000
for 10 GBit
The OIDs like .1.3.6.1.2.1.2.2.1.5.1 can only show the 1410065408 as this is the maximum possible with 32 bit signed integers.
If you search the internet for information about your switch and SNMP problems you will find many complains.
Thank you for your help.
Is there a mechanism in checkmk to correct/replace these values?
You can only set an assumed input/output speed. This is then used for the calculation of the utilization.
