I try to write some SNMP checks for 2.0.0pX
Unfortunatly the documentation https://docs.checkmk.com/latest/en/devel_check_plugins.html does not help very much. I searched this forum and found some hints, but nothing got me in the right direction yet. The SNMP checks delivered with checkmk that i found so far are using the old methods.
We have multiple devices that deliver many information and state by SNMP. I wanted to try something simple first and check the Dell Compellent Power Supply.
For the Dell Compellent there are some checks already delivered with check_mk but those are using the legacy checks as well.
I could also not find any SNMP check using v2 mechanism in the exchange.
So here is what i have and tried so far:
Partially output of OIDs
#.1.3.6.1.4.1.674.11000.2000.500.1.2.1.0 Dell-Compellent Storage Center
#.1.3.6.1.4.1.674.11000.2000.500.1.2.17.1.2.1.1 1
#.1.3.6.1.4.1.674.11000.2000.500.1.2.17.1.2.1.2 2
#.1.3.6.1.4.1.674.11000.2000.500.1.2.17.1.3.1.1 1
#.1.3.6.1.4.1.674.11000.2000.500.1.2.17.1.3.1.2 1
#.1.3.6.1.4.1.674.11000.2000.500.1.2.17.1.4.1.1 Power Supply 1
#.1.3.6.1.4.1.674.11000.2000.500.1.2.17.1.4.1.2 Power Supply 2
#.1.3.6.1.4.1.674.11000.2000.500.1.2.17.1.5.1.1 Empty
#.1.3.6.1.4.1.674.11000.2000.500.1.2.17.1.5.1.2 Empty
Error in agent based plugin dell_compellent_power: invalid characters in OID descriptor: ' '
I would really appreciate a link to a good and complete documentation for writing 2.0 SNMP checks. Or the name of a delivered plugin that already uses the new way of SNMP checks to get started.
a bit further, i discovered a few SNMP checks using the new mechanisms. So I tried to adapt it to my check.
Well i do not get an error anymore, but no inventory or check as well…
Maybe someone can push me in the right direction. What i got so far:
Thanks a lot sander. I learned another bit of Python and that i will have to learn Python before i continue.
Maybe the other compellent checks will be implemented as default cmk plug-in soon.
I just thought i could “easily” build checks for PowerSupply, Fan and Volume checks that the, not working with 2.0, check from the exchange had. Well, not that easy
