I noticed in the syslog of my server that there are many udp connections in a short time, is this normal in your opinion?
Thank you
Here the logs:
Nov 16 12:42:42 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:34391->[$IP_MONITORED_HOST]:161
Nov 16 12:42:42 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:47832->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:47832->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:43374->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:40390->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:40416->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:52302->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:47390->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:39327->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:57981->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:39053->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:55160->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:39570->[$IP_MONITORED_HOST]:161
Nov 16 12:42:43 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:51014->[$IP_MONITORED_HOST]:161
Nov 16 12:42:44 $Host snmpd[17513]: Connection from UDP: [$IP_CHECKMK_SERVER]:52538->[$IP_MONITORED_HOST]:161
Nov 16 12:42:51 $Host snmpd[17513]: error on subcontainer ‘ia_addr’ insert (-1)
