Currently getting an issue where pushing changes to a slave takes over 110 seconds. The GUI says the slave is then dead, but it seems to be pushing it on the back-end.
But is there anyway to up this timeout? As i understand its the webserver. the timeout directive in my proxy-port.conf is set to 600 on both slave and master.
Thanks in advance
Hi Chris,
if you’re running p14 and older please do an upgrade to p15. Since p11 we have several issues with livestatus:
Dear friends of Checkmk,
the new stable release 1.6.0p15 of Checkmk is ready for download.
This maintenance release ships with 13 changes affecing all editions of
Checkmk, 1 Enterprise Edition specific changes and 0 Managed Services Edition
specific changes.
The most important change is a fix for unstable livestatus communication
(#11258) that occured since 1.6.0p12.
Changes in all Checkmk Editions:
Checks & agents:
11149 mkp_prometheus: addition of mkp version 1.2
NOTE: Please refer …
Update on my master or slave?
First on your slave. If that works you can update all sites.
BR
Anastasios
so my master would be 1.6.0p6 but my slave 1.6.0p15? should that work?
athomaidis
(anastasios)
August 11, 2020, 11:18am
6
Yes. This is possible and should work.
Please do backup of your slave before the upgrade to p15.
will try it now, thanks for assistance
system
(system)
Closed
September 10, 2020, 9:22pm
8
