After the upgrade to 1.6.0p18, I cannot activate changes. If someone have the CLI or the steps I need to clear everything. I try with the API without success (the user automate doest own the change)
When I activate changes, the GUI does nothing and the page reload with all my changes pending.
I found the problem. I make a mistake to a ldap configuration, and it add +7000 users. I delete those user in /opt/omd/sites/site/var/check_mk/web and everything work perfectly.
Its possible to add an option to remove old account when you synchronise ldap user in the GUI?
