Hi team
i am using check_mk 1.6 .
can we set up user accounts with Active directory ?
if yes please guide me the process.
Regards
Manoj
Hi team
Regards
Manoj
HI Andres
I go throught the URL Document.
in our case we have simpled ad service exist in aws , which we are managing using active directory .
can you please tell me how exactly i should go in this case ?
can i use the users which i have already created in existing active directory for connecting to check_mk?
The bind credentials are a user account who has login and browse rights inside the AD.
After this save your config and test if a login is possible with the save and test option. But save first one time
I cannot help with the specials for AWS, as i have no AD system inside AWS here.
It is what is written inside the docs - path to users and filter settings for the users you want to sync to your system.
hi Andreas
thanks for the reply it was very helpful
