Add local check does not work
i want to add a local check to my monitoring for one host precisely.
I followed this tutorial which is very well explained ( [ check_mk 5 ] How to add a custom local service check in check_mk monitoring - YouTube ) about how to add local checks.
So on my host in /urs/lib/check_mk_agent/local theres a little simple script for testing with this content:
#!/bin/bash
if [[ -f /tmp/hello ]]; then
  status=0
  statustxt="hello file exists"
else
  status=2
  statustxt="hello file missing"
fi
echo "$status FileCheck_hello - $statustxt"
unfortunately it does not even show up in check _mk after a full scan.
Did i miss something?
best regards
Ah i forgot mention, we use check_mk1.6
best regards
Is it executable ?
chmod 755
Peter
Hi Peter,
yes its set to 755
I tried it on my site ( 1.6 ). There is a new local check FileCheck_hello
On the host, /usr/bin/check_mk_agent >/tmp/log. Search in the log for <<<local
This is in my logfile
2 FileCheck_hello - hello file missing
Hey Alessio,
I think that your problem ist very simple, because you use the wrong directory. If you want to install own PlugIns, so it is better to use: /usr/lib/check_mk_agent/plugins
Best regards
Matthias
hm its not a plugin its a local check for a single host. Anyway i tried the other directory, it does not work either :confused:
Permisson are 755, the owner is root, script works fine if i execute it
Just to be sure, it is in the right directory
grep MK_LIBDIR /usr/bin/check_mk_agent
export MK_LIBDIR=’/usr/lib/check_mk_agent’
PLUGINSDIR=$MK_LIBDIR/plugins
LOCALDIR=$MK_LIBDIR/local
What is your output from the grep ?
Peter
