Missing monitoring data for check plugins: proxmox_ve_mem_usage, proxmox_ve_vm_info, proxmox_ve_vm_snapshot_age
Calling: /omd/sites/cmk/share/check_mk/agents/special/agent_proxmox_ve '-u' 'XXX@XXX '-p' 'XXXXXX' '--port' 8006 '--no-cert-check' 'pvex-0.domain.de'
Write data to cache file /omd/sites/cmk/tmp/check_mk/data_source_cache/special_proxmox_ve/pvex-0.domain.de
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/data_source_cache/special_proxmox_ve/pvex-0.domain.de
Got lock on /omd/sites/cmk/tmp/check_mk/data_source_cache/special_proxmox_ve/pvex-0.domain.de
Releasing lock on /omd/sites/cmk/tmp/check_mk/data_source_cache/special_proxmox_ve/pvex-0.domain.de
Released lock on /omd/sites/cmk/tmp/check_mk/data_source_cache/special_proxmox_ve/pvex-0.domain.de
The file /omd/sites/cmk/tmp/check_mk/data_source_cache/special_proxmox_ve/pvex-0.domain.de is empty
/opt/omd/versions/2.0.0p31.cre/share/check_mk/agents/special/agent_proxmox_ve --verbose --debug -u Check_MK@pve -p 'XXXXXXXX' '--port' 8006 '--no-cert-check' '--timeout' 60 myhostname.net
INFO 2022-12-15 10:48:21 root: running file /omd/sites/it/lib/python3/cmk/special_agents/utils/agent_common.py
INFO 2022-12-15 10:48:21 root: using Python interpreter v3.8.15.final.0 at /omd/sites/it/bin/python3
INFO 2022-12-15 10:48:21 agent_proxmox_ve: Establish connection to Proxmox VE host 'myhostname.net'
INFO 2022-12-15 10:48:21 agent_proxmox_ve: Fetch general cluster and node information..
INFO 2022-12-15 10:48:22 agent_proxmox_ve: Fetch and process backup logs..
WARNING 2022-12-15 10:48:22 cmk.special_agents.utils.misc: Cache: could not find file - start a new one
INFO 2022-12-15 10:48:22 agent_proxmox_ve: all VMs: ['1000', '101', '101020001', '10102002', '102', '200']
INFO 2022-12-15 10:48:22 agent_proxmox_ve: expected backups: []
INFO 2022-12-15 10:48:22 agent_proxmox_ve: actual backups: []
INFO 2022-12-15 10:48:22 agent_proxmox_ve: snaptimes: {'200': {'snaptimes': []}, '101020001': {'snaptimes': []}, '1000': {'snaptimes': []}, '10102002': {'snaptimes': []}, '101': {'snaptimes': []}, '102': {'snaptimes': []}}
INFO 2022-12-15 10:48:22 agent_proxmox_ve: Write agent output..
<<<proxmox_ve_node_info:sep(0)>>>
File "/opt/omd/versions/2.0.0p31.cre/share/check_mk/agents/special/agent_proxmox_ve", line 10, in <module>
main()
File "/omd/sites/it/lib/python3/cmk/special_agents/agent_proxmox_ve.py", line 757, in main
special_agent_main(parse_arguments, agent_proxmox_ve_main)
File "/omd/sites/it/lib/python3/cmk/special_agents/utils/agent_common.py", line 159, in special_agent_main
_special_agent_main_core(parse_arguments, main_fn, sys.argv[1:])
File "/omd/sites/it/lib/python3/cmk/special_agents/utils/agent_common.py", line 141, in _special_agent_main_core
main_fn(args)
File "/omd/sites/it/lib/python3/cmk/special_agents/agent_proxmox_ve.py", line 502, in agent_proxmox_ve_main
"time_info": node["time"],
KeyError: 'time'
I believe it has something to do with the remaining time of the subscription. Too bad if you don’t have any…
By just replacing node['time'] with something else in /opt/omd/versions/2.0.0p32.cre/lib/python3/cmk/special_agents/agent_proxmox_ve.py I was able to get both services directly on the host and also all the piggybacked services back.
This could ultimately be fixed by checking if time in node, but somebody with a valid subscription can maybe tell what this variable usually holds.
