CMK version:
Checkmk Raw Edition 2.1.0
OS version:
Ubuntu 20.4
No services are discovered vie IPMI
Connection tests shows monitoring Data but nothing discovered at the services.
Output Connectiontest:
<<<check_mk>>>
Version: 2.0.0p11
AgentOS: linux
Hostname: x-l-px01
AgentDirectory: /etc/check_mk
DataDirectory: /var/lib/check_mk_agent
SpoolDirectory: /var/lib/check_mk_agent/spool
PluginsDirectory: /usr/lib/check_mk_agent/plugins
LocalDirectory: /usr/lib/check_mk_agent/local
<<<ipmi:sep(124):cached(1654000603,300)>>>
System Temp | 26.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 75.000 | 77.000 | 79.000
CPU1 Vcore | 1.016 | Volts | ok | 0.656 | 0.664 | 0.672 | 1.352 | 1.360 | 1.368
CPU2 Vcore | 1.200 | Volts | ok | 0.656 | 0.664 | 0.672 | 1.352 | 1.360 | 1.368
CPU1 DIMM | 1.584 | Volts | ok | 1.184 | 1.192 | 1.200 | 1.648 | 1.656 | 1.664
CPU2 DIMM | 1.584 | Volts | ok | 1.184 | 1.192 | 1.200 | 1.648 | 1.656 | 1.664
+1.5V | 1.512 | Volts | ok | 1.320 | 1.328 | 1.336 | 1.656 | 1.664 | 1.672
+3.3V | 3.288 | Volts | ok | 2.880 | 2.904 | 2.928 | 3.648 | 3.672 | 3.696
+3.3VSB | 3.240 | Volts | ok | 2.880 | 2.904 | 2.928 | 3.648 | 3.672 | 3.696
+5V | 5.088 | Volts | ok | 4.416 | 4.448 | 4.480 | 5.536 | 5.568 | 5.600
+12V | 12.137 | Volts | ok | 10.600 | 10.653 | 10.706 | 13.250 | 13.303 | 13.356
VBAT | 3.216 | Volts | ok | 2.880 | 2.904 | 2.928 | 3.648 | 3.672 | 3.696
Fan1 | 4185.000 | RPM | ok | 405.000 | 540.000 | 675.000 | 34155.000 | 34290.000 | 34425.000
Fan2 | 4320.000 | RPM | ok | 405.000 | 540.000 | 675.000 | 34155.000 | 34290.000 | 34425.000
Fan3 | 4320.000 | RPM | ok | 405.000 | 540.000 | 675.000 | 34155.000 | 34290.000 | 34425.000
P1-DIMM1A Temp | 42.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000
P1-DIMM2A Temp | 38.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000
P1-DIMM3A Temp | 37.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000
P2-DIMM1A Temp | 36.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000
P2-DIMM2A Temp | 31.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000
P2-DIMM3A Temp | na | degrees C | na | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000
<<<ipmi_discrete:sep(124):cached(1654000795,300)>>>
<<<ntp:cached(1654000795,30)>>>
% 0.debian.pool.n .POOL. 16 p - 64 0 0.000 +0.000 0.000
% 1.debian.pool.n .POOL. 16 p - 64 0 0.000 +0.000 0.000
% 2.debian.pool.n .POOL. 16 p - 64 0 0.000 +0.000 0.000
% 3.debian.pool.n .POOL. 16 p - 64 0 0.000 +0.000 0.000
+ 131.130.251.107 .GPS. 1 u 922 1024 377 4.466 -0.207 4.513
- 185.242.177.6 217.196.145.42 2 u 769 1024 377 1.025 -0.333 0.240
* 193.171.23.163 .PZF. 1 u 534 1024 377 3.960 -0.202 0.067
- 86.59.80.170 40.179.132.91 2 u 686 1024 377 5.864 -0.303 0.056
+ 217.196.145.42 .GPS. 1 u 363 1024 377 2.870 -0.184 0.601
- 185.236.167.60 193.171.23.163 2 u 861 1024 377 5.594 -0.556 0.125
<<<local:sep(0)>>>
cached(1653999724,21600) 0 check-bpc/at-ext-bpc01 - at-ext-bpc01 is OK
cached(1653999724,21600) 0 check-bpc/ibbg-ext-bpc01 - ibbg-ext-bpc01 is OK
cached(1653999724,21600) 0 check-bpc/wil-ext-bpc01 - wil-ext-bpc01 is OK
cached(1653999724,21600) 0 check-bpc/x-l-apache02 - x-l-apache02 is OK
cached(1653999724,21600) 0 check-bpc/x-l-fog01 - x-l-fog01 is OK
cached(1653999724,21600) 0 check-bpc/x-l-restyaboard01 - x-l-restyaboard01 is OK
cached(1653999724,21600) 0 check-bpc/x-l-samba03 - x-l-samba03 is OK
<<<qemu>>>
20091505 ls-testserver stopped
20091523 ae-win10 running 7177 3.1 6.4
20091620 x-l-restyaboard01 running 3499 3.3 2.7
20121701 x-l-samba03 running 4363 3.3 2.9
21012601 at-ext-bpc01 running 3403 3.3 1.8
21012602 wil-ext-bpc01 running 3404 3.3 1.8
21012801 ibbg-ext-bpc01 running 3405 6.6 1.8
21061501 x-l-apache02 running 4364 3.3 3.3
22042800 x-l-fog01 running 3553 0 3.1
<<<ceph_status>>>
"fsid": "71e2eef4-3cfd-4b83-8d28-26e12e5113e4",
"health": {
"status": "HEALTH_OK",
"checks": {},
"mutes": []
"election_epoch": 13254,
"quorum": [
0,
1,
2,
3,
4
"quorum_names": [
"x-l-px02",
"x-l-px01",
"x-l-px03",
"x-l-px04",
"x-l-px05"
"quorum_age": 721754,
"monmap": {
"epoch": 8,
"min_mon_release_name": "octopus",
"num_mons": 5
"osdmap": {
"epoch": 50465,
"num_osds": 47,
"num_up_osds": 45,
"osd_up_since": 1652290703,
"num_in_osds": 45,
"osd_in_since": 1652780289,
"num_remapped_pgs": 0
"pgmap": {
"pgs_by_state": [
"state_name": "active+clean",
"count": 1185
"num_pgs": 1185,
"num_pools": 4,
"num_objects": 6067080,
"data_bytes": 24407628251702,
"bytes_used": 71309025619968,
"bytes_avail": 68216921247744,
"bytes_total": 139525946867712,
"read_bytes_sec": 18042730,
"write_bytes_sec": 16750312,
"read_op_per_sec": 125,
"write_op_per_sec": 69
"fsmap": {
"epoch": 1,
"by_rank": [],
"up:standby": 0
"mgrmap": {
"available": true,
"num_standbys": 1,
"modules": [
"diskprediction_cloud",
"diskprediction_local",
"iostat",
"restful"
"services": {}
"servicemap": {
"epoch": 1009508,
"modified": "2022-05-31T14:37:09.590636+0200",
"services": {}
"progress_events": {}
<<<ceph_df_json:sep(0)>>>
{"version":"ceph version 15.2.15 (efc1e7ef13525f02d58d97ccd62fec325323c618) octopus (stable)"}
{"stats":{"total_bytes":139525946867712,"total_avail_bytes":68216887599104,"total_used_bytes":71150278582272,"total_used_raw_bytes":71309059268608,"total_used_raw_ratio":0.51108098030090332,"num_osds":45,"num_per_pool_osds":45,"num_per_pool_omap_osds":45},"stats_by_class":{"hdd":{"total_bytes":23003110834176,"total_avail_bytes":13294866333696,"total_used_bytes":9682822037504,"total_used_raw_bytes":9708244500480,"total_used_raw_ratio":0.42204049229621887},"hdd_big":{"total_bytes":106020735025152,"total_avail_bytes":48625427873792,"total_used_bytes":57273689833472,"total_used_raw_bytes":57395307151360,"total_used_raw_ratio":0.5413593053817749},"nvme":{"total_bytes":10502101008384,"total_avail_bytes":6296593391616,"total_used_bytes":4193766711296,"total_used_raw_bytes":4205507616768,"total_used_raw_ratio":0.4004443883895874}},"pools":[{"name":"device_health_metrics","id":2,"stats":{"stored":131041784,"stored_data":0,"stored_omap":131041784,"objects":71,"kb_used":383912,"bytes_used":393125330,"data_bytes_used":0,"omap_bytes_used":393125330,"percent_used":1.0650449439708609e-05,"max_avail":12303742271488,"quota_objects":0,"quota_bytes":0,"dirty":0,"rd":53435,"rd_bytes":42557078528,"wr":37124,"wr_bytes":295967744,"compress_bytes_used":0,"compress_under_bytes":0,"stored_raw":393125344,"avail_raw":36911226285057}},{"name":"hdd_pool","id":5,"stats":{"stored":3225646094969,"stored_data":3225629753344,"stored_omap":16341625,"objects":781744,"kb_used":9454450884,"bytes_used":9681357705068,"data_bytes_used":9681308680192,"omap_bytes_used":49024876,"percent_used":0.47664555907249451,"max_avail":3543360602112,"quota_objects":0,"quota_bytes":0,"dirty":0,"rd":891713261,"rd_bytes":57989182424064,"wr":1806567684,"wr_bytes":46292987526144,"compress_bytes_used":0,"compress_under_bytes":0,"stored_raw":9676937756672,"avail_raw":10630081647251}},{"name":"slow_pool","id":8,"stats":{"stored":20380080361266,"stored_data":20380056027136,"stored_omap":24334130,"objects":4924548,"kb_used":59718905084,"bytes_used":61152158805398,"data_bytes_used":61152085803008,"omap_bytes_used":73002390,"percent_used":0.59121823310852051,"max_avail":14093998096384,"quota_objects":0,"quota_bytes":0,"dirty":0,"rd":12168963397,"rd_bytes":859099915932672,"wr":1633035383,"wr_bytes":871385341727744,"compress_bytes_used":0,"compress_under_bytes":0,"stored_raw":61140243578880,"avail_raw":42281994804796}},{"name":"nvme_pool","id":11,"stats":{"stored":1397739134435,"stored_data":1397723234304,"stored_omap":15900131,"objects":360717,"kb_used":4095386351,"bytes_used":4193675622822,"data_bytes_used":4193627922432,"omap_bytes_used":47700390,"percent_used":0.61637204885482788,"max_avail":870043549696,"quota_objects":0,"quota_bytes":0,"dirty":0,"rd":2241393767,"rd_bytes":164249379331072,"wr":1762747813,"wr_bytes":43417634689024,"compress_bytes_used":0,"compress_under_bytes":0,"stored_raw":4193217150976,"avail_raw":2610130513255}}]}
<<<logwatch>>>
[[[/var/log/auth.log]]]
[[[/var/log/kern.log]]]
[[[/var/log/messages]]]
[[[/var/log/syslog]]]
<<<smart>>>
HGST_HUS726040AL5210_N8H2GD0Z HGST HUS726040AL5210 194 Temperature_Celsius 0x0000 000 000 000 Old_age Always - 36 (0 0 0 0)
HGST_HUS726040AL5210_N8H2GENZ HGST HUS726040AL5210 194 Temperature_Celsius 0x0000 000 000 000 Old_age Always - 34 (0 0 0 0)
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 32832
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 22
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 177 Wear_Leveling_Count 0x0013 092 092 005 Pre-fail Always - 2807
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 180 Unused_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 1374
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 194 Temperature_Celsius 0x0022 070 051 000 Old_age Always - 30 (Min/Max 27/49)
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 202 Exception_Mode_Status 0x0033 100 100 010 Pre-fail Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 9
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 736320329004
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 242 Total_LBAs_Read 0x0032 099 099 000 Old_age Always - 239994869957
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 243 SATA_Downshift_Ct 0x0032 100 100 000 Old_age Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 244 Thermal_Throttle_St 0x0032 100 100 000 Old_age Always - 0
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 245 Timed_Workld_Media_Wear 0x0032 100 100 000 Old_age Always - 65535
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 246 Timed_Workld_RdWr_Ratio 0x0032 100 100 000 Old_age Always - 65535
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 247 Timed_Workld_Timer 0x0032 100 100 000 Old_age Always - 65535
SAMSUNG_MZ7KM240HMHQ-00005_S3F5NX0K408326 ATA SAMSUNG_MZ7KM240 251 NAND_Writes 0x0032 100 100 000 Old_age Always - 1471066071552
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 10756
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 9
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 170 Unused_Rsvd_Blk_Ct_Chip 0x0032 100 100 010 Old_age Always - 0
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 171 Program_Fail_Count_Chip 0x0032 100 100 010 Old_age Always - 0
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 172 Erase_Fail_Count_Chip 0x0032 100 100 010 Old_age Always - 0
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 173 Wear_Leveling_Count 0x0033 001 001 005 Pre-fail Always FAILING_NOW 1345
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 174 Unexpect_Power_Loss_Ct 0x0032 099 099 000 Old_age Always - 2
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 178 Used_Rsvd_Blk_Cnt_Chip 0x0013 100 100 010 Pre-fail Always - 0
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 180 Unused_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 629
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 194 Temperature_Celsius 0x0032 071 057 000 Old_age Always - 29
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 199 CRC_Error_Count 0x003e 099 099 000 Old_age Always - 1
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 233 Media_Wearout_Indicator 0x0013 001 001 000 Pre-fail Always - 172637983688622
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 26861
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 242 Total_LBAs_Read 0x0032 099 099 000 Old_age Always - 5790
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 249 NAND_Writes_1GiB 0x0032 099 099 000 Old_age Always - 340763
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 250 SATA_Iface_Downshift 0x0032 099 099 000 Old_age Always - 56332016883
SAMSUNG_MZ7LN256HAJQ-00000_S3TWNX1N103487 ATA SAMSUNG_MZ7LN256 251 NAND_Writes 0x0032 099 099 000 Old_age Always - 714633337280
/dev/nvme1n1 NVME Samsung_SSD_970_PRO_1TB
Critical Warning: 0x00
Temperature: 32 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 18%
Data Units Read: 52,115,151 [26.6 TB]
Data Units Written: 193,647,431 [99.1 TB]
Host Read Commands: 283,264,229
Host Write Commands: 3,426,715,738
Controller Busy Time: 66,454
Power Cycles: 10
Power On Hours: 12,077
Unsafe Shutdowns: 5
Media and Data Integrity Errors: 0
Error Information Log Entries: 2
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 32 Celsius
Temperature Sensor 2: 34 Celsius
/dev/nvme0n1 NVME Samsung_SSD_980_PRO_2TB
Temperature: 38 Celsius
Percentage Used: 6%
Data Units Read: 164,560,288 [84.2 TB]
Data Units Written: 51,942,149 [26.5 TB]
Host Read Commands: 2,010,451,995
Host Write Commands: 1,861,797,309
Controller Busy Time: 63,862
Power Cycles: 5
Power On Hours: 9,014
Unsafe Shutdowns: 0
Error Information Log Entries: 0
Temperature Sensor 1: 38 Celsius
Temperature Sensor 2: 45 Celsius
<<<ipmi_sensors:sep(124)>>>
1|CPU1 Temp|UNKNOWN type 192|N/A||OK
2|CPU2 Temp|UNKNOWN type 192|N/A||OK
3|System Temp|Temperature|26.00|°C|OK
4|CPU1 Vcore|Voltage|1.01|V|OK
5|CPU2 Vcore|Voltage|0.98|V|OK
6|CPU1 DIMM|Voltage|1.58|V|OK
7|CPU2 DIMM|Voltage|1.58|V|OK
8|+1.5V|Voltage|1.51|V|OK
9|+3.3V|Voltage|3.26|V|OK
10|+3.3VSB|Voltage|3.24|V|OK
11|+5V|Voltage|5.09|V|OK
12|+12V|Voltage|12.19|V|OK
13|VBAT|Voltage|3.22|V|OK
14|Fan1|Fan|4185.00|RPM|OK
15|Fan2|Fan|4320.00|RPM|OK
16|Fan3|Fan|4320.00|RPM|OK
96|P1-DIMM1A Temp|Temperature|42.00|°C|OK
98|P1-DIMM2A Temp|Temperature|38.00|°C|OK
100|P1-DIMM3A Temp|Temperature|37.00|°C|OK
102|P2-DIMM1A Temp|Temperature|36.00|°C|OK
104|P2-DIMM2A Temp|Temperature|31.00|°C|OK
106|P2-DIMM3A Temp|Temperature|N/A|°C|OK
170|Intrusion|Physical Security|N/A||OK
22|PS Status|Power Supply|N/A||OK
<<<ipmi_firmware:sep(124)>>>
BMC Version|version|2.8
