CMK version:
2.1.0p22
OS version:
ubuntu 22.04
telnet: Unable to connect to remote host: Connection refused
OMD[monitoring]:~$ cmk --debug -vvn psbecmk1
Checkmk version 2.1.0p22
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Updating IPv4 DNS cache for psbecmk1: 127.0.0.1
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/ipaddresses.cache
Got lock on /omd/sites/monitoring/var/check_mk/ipaddresses.cache
Releasing lock on /omd/sites/monitoring/var/check_mk/ipaddresses.cache
Released lock on /omd/sites/monitoring/var/check_mk/ipaddresses.cache
- FETCHING DATA
[cpu_tracking] Start [7f0fbf8bd340]
[PiggybackFetcher] Fetch with cache settings: NoCache(psbecmk1, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for ‘psbecmk1’. Skip processing.
No piggyback files for ‘127.0.0.1’. Skip processing.
[cpu_tracking] Stop [7f0fbf8bd340 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))] - PARSE FETCHER RESULTS
No persisted sections
→ Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f0fbf8bd430]
value store: synchronizing
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/counters/psbecmk1
Got lock on /omd/sites/monitoring/tmp/check_mk/counters/psbecmk1
Releasing lock on /omd/sites/monitoring/tmp/check_mk/counters/psbecmk1
Released lock on /omd/sites/monitoring/tmp/check_mk/counters/psbecmk1
[cpu_tracking] Stop [7f0fbf8bd430 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
execution time 0.0 sec | execution_time=0.000 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
on another one
OMD[monitoring]:~$ cmk --debug -vvn ogramos01
- FETCHING DATA
[cpu_tracking] Start [7fad960a7910]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(ogramos01, base_path=/omd/sites/monitoring/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Connecting via TCP to 192.168.11.110:6556 (5.0s timeout)
Closing TCP connection to 192.168.11.110:6556
[cpu_tracking] Stop [7fad960a7910 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=5.009999997913837))]
[cpu_tracking] Start [7fad960a73d0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(ogramos01, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Write data to cache file /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/ogramos01
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/ogramos01
Got lock on /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/ogramos01
Releasing lock on /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/ogramos01
Released lock on /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/ogramos01
[cpu_tracking] Stop [7fad960a73d0 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
[cpu_tracking] Start [7fad96119fd0]
[PiggybackFetcher] Fetch with cache settings: NoCache(ogramos01, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for ‘ogramos01’. Skip processing.
No piggyback files for ‘192.168.11.110’. Skip processing.
[cpu_tracking] Stop [7fad96119fd0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))] - PARSE FETCHER RESULTS
→ Not adding sections: timeout(‘timed out’)
→ Add sections: []
→ Add sections: []
[cpu_tracking] Start [7fad96119af0]
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/counters/ogramos01
Got lock on /omd/sites/monitoring/tmp/check_mk/counters/ogramos01
Releasing lock on /omd/sites/monitoring/tmp/check_mk/counters/ogramos01
Released lock on /omd/sites/monitoring/tmp/check_mk/counters/ogramos01
[cpu_tracking] Stop [7fad96119af0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[agent] timeout(‘timed out’)(!!), [snmp] Success, execution time 5.0 sec | execution_time=5.020 user_time=0.010 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=5.010 cmk_time_snmp=0.000
i got “connection refused” errno 111
even with local command: telnet localhost 6556
do you any hint ?
thank you in advance,
Eric
