what is the right way to build a dummy agent for the bakery to use as first generic target via curl/ wget to pull the individual package in the next step?
Configuring a host for every os and insert the update plugin?
Thanks
Ralf
Thanks
Ralf
One agent with only update plugin configured would be enough.
I have such agents in most installations as the “Default” agent configured.
thanks. Means one dummy host too?
Ralf
No - with default i mean the “Generic” agent this one is build with the rules in the main directory.
Make sure that the GENERIC
agent package does not contain any credentials, just the agent updater plugin and other generic plugins. This can be achieved by not specifying any conditions in the updater configuration rule.
This way you can put that package (.deb
, .rpm
and .msi
versions) on a webserver without authentication and you have URLs for your automatic software deployment tool to install the agent.
Ok,
thanks.
How do I build a generic client or does one exist by default?
Ralf
There is every time a generic client. The same as the Vanilla client exists in every installation.
The GENERIC
agent package contains all the configuration from the rules that do not have any conditions.
The bakery will build that package for you. Just look for it after baking.
