Hi - I am not a DB2 expert at all; but we are successfully running the DB2 plugin (delivered by checkmk resp. in a newer release at their exchange including a bug fix for DB2 vesion >= 10.5); the plugin is split into two parts called mk_db.linux and db2_mem.
Where did you get the .aix version? Can’t see any .aix version for DB2 in our installation so far. Moreover, is there also a second add-on for the mem-part as well?
The AIX version should be there as “mk_db2.aix” it is the older one i think
One of my customers is using the DB2 plugin on AIX but i cannot say anything about the setup and versions as I’m not know anything about the AIX systems.
@jstallsmith in your case it looks like it find only the instance and version. I would do a test with the next steps the script is doing in a manual way. Like
db2 list database directory on $HOMEDIR
The homedir can be used explicitly or you try the mechanic from the script.
# db2 list database directory on $HOMEDIR
SQL0104N An unexpected token "END-OF-STATEMENT" was found following "ON".
Expected tokens may include: "<identifier>". SQLSTATE=42601
I am experiencing the same issue with this plugin. I tried to troubleshoot the commands one by one and I did not get very far.
The db2_mem works fine, it’s a very simple and quick script. But the mk_db2.aix does not produce output… beyond what jstallsmith indicated in the original post.
