I’m trying to optimize our check_mk RAW performance, especially in WATO since it’s DEAD slow…
Just discovered the “Analyze configuration” feature and one of the things it’s found is:
external CRIT: The current livestatus usage is 100.00% (!!), 20 of 20 connections used (!!), You have a connection overflow rate of 0.00/s (!!)
I was trying to find how can I increase the number of connections but I get nothing.
Could you please advise how to increase the number of livestatus connection limit?
Hi, a few days ago I had read here in the forum that the RAW Edition always has 100% livestatus usage on the “Analyze configuration” page.
Sorry, it is a german thread: Livestatus usage
If you use the Raw edition then ignore these messages. Only look at the graphs for the check latency.
If these graphs stay low all is fine. Also you can have a look at the livestatus connection graph for the amount of connections per time frame.
Hi, could you tell me please where i can configure this value at the CheckMK 2 RAW? I didnt find any settings for the “Maximum concurrent Livestatus connections” or something in the Webinterface but i want to raise up this value a little bit. The directory etc/mk-livestatus including the nagios.cfg doesnt exist. I cant find anything in the web…or is it impossible in the RAW Edition? Thanks a lot!
