I try monitoring my office 365 mailboxes and the office365-synchronization between my on-premise-ad and the azure-ad. I thought that Azure-Plugin should solve my problem and followed the following instructions (https://checkmk.de/cms_monitoring_azure.html).
Unfortunally this is not working. There is no error message so the login should seems to work but there seems to be no data provided. The only service I see is the following:
CRIT Azure Agent Info af76e3e5-5f98-4bd1-8428-7aa39f3ac347)(!!), Monitored groups: , 0 warnings, 0 exceptions
First it would be good to inspect the real agent output you get.
Go to the command line and as the site user do a “cmk -D hostname” where “hostname” is the name of your Azure pseudo host. Execute the special agent command shown and inspect the output.
You can also execute the special agent with debug option to get a little bit more output.
What CMK version do you use - there where some changes to the Azure agent over the past months.
The billing error is correct MS changed something in the billing API. I made a new version for the current billing API but need to submit this fix
If i see it correct the AD section is not included in the current 1.6 version only in the next (1.7 dev).
