Looks like that the parameter changed. Please run cmk --debu -vv on CLI. In the output you will find the call of the special agent. I think there is the parameter --secret missing .
secret is a stdin now. In order to make the script work, you have to run it like this:
echo ‘{secret=“blabla”}’ | ~/share/check_mk/agents/special/azure_agent/…
If you need to manually test it is also possible to add the “–secret” option to the special agent call.
The command line option is not removed from the special agent.
Now I installed the new checkmk 2.0.0b5 and the azure agent works fine again.
The only thing is, that “-” in the ressource group name is converted to “_” for the piggyback host.
