Azure Ressource group with SQL Databaes + Elastic Pool could not be created
We are currently working on moving all databases that are separately in customer resource groups into a single RSG.
We have done that (90% of RSGs), now we wanted to monitor it in check-mk. The process should be easy.
I created a new host with the name of the new resource group. Unfortunately he can’t find any resources within.
the new RSG looks like as follows:
Before we moved the databases to the new RSG, we also monitored it and it worked without any problems.
Example of a still not moved RSG:
The subscription is the same.
thx
FIXED, i had to add the explicit RSG to the existing AZURE RULE.
