Hello All, I have discovered checkmk very recently and I am currently testing it to see if this is something I can implement to monitor VMs on multiple platforms. Everything is currently a testing environment.
The problem: I have successfully created an API Integration and I was able to create a host for my Rescource Group: Demo-RG.
Then i have created a separate host for a VM running in Azure with PiggyBacking enabled. Unfortunately barely any information is being picked up.
I’m trying to get the CPU/Disk/Network usage come from the VM Monitoring if possible, but i have hit a brick wall and I am unable to figure out what I am doing wrong.
Any help would be highly appreciated!
I have followed this guide and on on Stage 3.4 you can see how in their screenshot Storages have been picked up, it didn’t happen in my instance:
(I have tried to give more details, but I can only add one screenshot)
CMK version: Checkmk Raw Edition 2.1.0p23
OS version: Debian 11
Error message: No Error message, but rather missing details in an Azure VM
OMD[monitoring]:~$ cmk --debug -vvn chkmktest
Checkmk version 2.1.0p23
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f2f32e93160]
[PiggybackFetcher] Fetch with cache settings: NoCache(chkmktest, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
Piggyback file '/omd/sites/monitoring/tmp/check_mk/piggyback/chkmktest/Demo-RG': Successfully processed from source 'Demo-RG'
[cpu_tracking] Stop [7f2f32e93160 - Snapshot(process=posix.times_result(user=0.0, system=0.020000000000000018, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
+ PARSE FETCHER RESULTS
<<<labels:cached(1678287016,90):sep(0)>>> / Transition NOOPParser -> HostSectionParser
<<<azure_virtualmachines:cached(1678287016,90):sep(124)>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
-> Add sections: ['azure_virtualmachines', 'labels']
Received no piggyback data
[cpu_tracking] Start [7f2f32e4b610]
value store: synchronizing
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/counters/chkmktest
Got lock on /omd/sites/monitoring/tmp/check_mk/counters/chkmktest
Releasing lock on /omd/sites/monitoring/tmp/check_mk/counters/chkmktest
Released lock on /omd/sites/monitoring/tmp/check_mk/counters/chkmktest
VM chkmktest Provisioning succeeded, VM running, Resource group: Demo-RG, Location: francecentral
+ EXECUTING INVENTORY PLUGINS
aruba_wlc_aps: skipped (no data)
check_mk: skipped (no data)
checkmk_agent_plugins: skipped (no data)
docker_node_info: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
ipmi_firmware: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
k8s_job_container: skipped (no data)
kube_cluster: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mobileiron_inventory: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_routes: skipped (no data)
statgrab_net: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_reg_uninstall: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_roles: skipped (no data)
lnx_if: skipped (no data)
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
snmp_info: skipped (no data)
winperf_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
allnet_ip_sensoric: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_node_name: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
netapp_api_info: skipped (no data)
perle_chassis: skipped (no data)
prtconf: skipped (no data)
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_os: skipped (no data)
win_system: skipped (no data)
[cpu_tracking] Stop [7f2f32e4b610 - Snapshot(process=posix.times_result(user=0.0, system=0.07000000000000006, children_user=0.0, children_system=0.0, elapsed=0.07999999821186066))]
[piggyback] Successfully processed from source 'Demo-RG', execution time 0.1 sec | execution_time=0.100 user_time=0.000 system_time=0.090 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
OMD[monitoring]:~$
