Best practice for merging two Checkmk sites and preserving historical RRD data?
We need to consolidate two Checkmk sites into a single site. Currently, one site acts as a central/master site receiving monitoring data from a remote/slave site, but the configuration is not centrally managed; the remote site maintains its own WATO configuration, folders, hosts, rules, tags, notifications, contact groups, and other objects locally.
Our goal is to decommission the remote site and merge everything into the master site. We are looking for recommendations, best practices, or supported procedures for migrating and merging WATO configuration (rules, folders, host tags, notifications, users/contact groups, BI aggregations, etc.) while avoiding conflicts with existing configuration in the target site.
One of our main concerns is preserving historical monitoring data and graphs. Is it sufficient to migrate/copy the RRD files (for example via rsync) and keep the same host and service names, or is there a recommended procedure/tool to migrate historical performance data safely?
Any experience, documentation, or lessons learned from similar site consolidation projects would be greatly appreciated.
BR
For reference that is not a new topic and there is a feature request for that as well:
Copying performance data should not be a problem as long as permissions matches the new site. If you have the possibility I would also suggest running both sites in the same server, at least for testing and ensuring that all networks and servers are reachable from it. Once both are running in the same server the migration would consist on copying the RRD files and modifying the site where the host is monitored. Also you need to consider Agent Updater and TLS registration which might be impacted according to how you have that in place.
