CMK version:
2.0.0p12
OS version:
CentOS Linux release 7.9.2009 (Core)
Problem is that from the checkmk server im able to telenet, im also able to do nc to the server and getting the whole agent output. If i go in the browser everything i blank. Any suggestions?
Checkmk version 2.0.0p12
Trying to acquire lock on /omd/sites/tten/var/check_mk/license_usage/next_run
Got lock on /omd/sites/tten/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/tten/var/check_mk/license_usage/history.json
Got lock on /omd/sites/tten/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/tten/var/check_mk/license_usage/history.json
Released lock on /omd/sites/tten/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/tten/var/check_mk/license_usage/next_run
Released lock on /omd/sites/tten/var/check_mk/license_usage/next_run
+ FETCHING DATA
Source: SourceType.HOST/FetcherType.PROGRAM
[cpu_tracking] Start [7f158f5a8430]
Calling: /omd/sites/tten/share/check_mk/agents/special/agent_proxmox_ve '-u' 'checkmk@pve' '-p' 'checkmk' '--port' 8006 '--no-cert-check' '--timeout' 60 '--log-cutoff-weeks' 2 'portainer'
[ProgramFetcher] Fetch with cache settings: DefaultAgentFileCache(base_path=PosixPath('/omd/sites/tten/tmp/check_mk/data_source_cache/special_proxmox_ve/portainer'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 119 sec, allowed is 0 sec)
Write data to cache file /omd/sites/tten/tmp/check_mk/data_source_cache/special_proxmox_ve/portainer
Trying to acquire lock on /omd/sites/tten/tmp/check_mk/data_source_cache/special_proxmox_ve/portainer
Got lock on /omd/sites/tten/tmp/check_mk/data_source_cache/special_proxmox_ve/portainer
Releasing lock on /omd/sites/tten/tmp/check_mk/data_source_cache/special_proxmox_ve/portainer
Released lock on /omd/sites/tten/tmp/check_mk/data_source_cache/special_proxmox_ve/portainer
[cpu_tracking] Stop [7f158f5a8430 - Snapshot(process=posix.times_result(user=0.010000000000000231, system=0.010000000000000009, children_user=0.39, children_system=0.12, elapsed=0.5499999998137355))]
[cpu_tracking] Start [7f158f5a87c0]
+ PARSE FETCHER RESULTS
No persisted sections loaded
-> Add sections: []
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/tten/tmp/check_mk/counters/portainer
Got lock on /omd/sites/tten/tmp/check_mk/counters/portainer
Releasing lock on /omd/sites/tten/tmp/check_mk/counters/portainer
Released lock on /omd/sites/tten/tmp/check_mk/counters/portainer
[cpu_tracking] Stop [7f158f5a87c0 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999999776482582))]
[special_proxmox_ve] Version: unknown, OS: unknown, execution time 0.6 sec | execution_time=0.560 user_time=0.020 system_time=0.010 children_user_time=0.390 children_system_time=0.120 cmk_time_ds=0.020
