Hey,
Looking for some clarification regarding the bulk notification seperation, been unable to find an answer elsewhere.
When selecting the tick boxes to use for seperation, eg Check Type, Folder, Host ect, are these an AND or and OR criteria? Eg if I select both Host and Service Name, will it bulk all notifications that either have the same service name or the same host or will it only bulk notifiations where the host and service name are the same?
I’m trying to setup bulk notifications for one service present on multiple hosts, have it set to 5min bulk period but I’m still getting individual emails within a 1 minute period. Currently have Folder, Host and Service Name selected for bulking but not getting any bulks, all individual.
Cheers!
Well seemed to have answered my own question after some playing around - they’re OR clauses. Created seperate rules for each bulk tick box and now getting bulks delivered.
hey,
do you mind sending your settings?
Yeah, is just a case of having seperate notification rules for each “Bulk Notification” tick box you wish.
So I have 2 notification rules for bulking. Both have “Bulk Notification” ticked and “Always bulk” selected in the drop down.
Then in one rule under “Seperate bulk notifications for” I have “Folder” ticked and in the second rule I have “Service Name” ticked.
If I had both “Folder” and “Service Name” ticked in the same notifiation rule I didn’t receive any bulks but seperate rules it’s now working.
So do you have two separate rules that are identical except for the bulking part? If so, wouldn’t that cause duplicate notifications if bulking is not needed (e.g. single notification)?
