We have some checks showing Warning (veeam backup jobs). We want to change these states from warning to ok. Is there some kind of rule to change this behavior?
BR
BR
Hi @korijn,
If I’m not mistaken you can’t do it in raw. In enterprise you have a rule for service state translate.
Just mute those services or create timeperiods to create a blackout during the backups, avoiding false positives and resuming as soon as the backup ends.
if you use the Enterprise Edition, there’s the rule “Service State Translation” for this.
Karl
Thank you for your answers.
We use Raw edition indeed, not enterprise.
I’m going to try to modify the check plugin to see weither i’m able to change Warning to OK.
Thank you!
