Hi!
The Check_MK Agent version is 1.5.0b7, the OMD version is 1.5.0 Raw Edition and the host is a RHEL 5.9.
The check_discovery service from my xyz_host is crashing.
The output of the command cmk --debug -vvI xyz_host
is:
Discovering services on: xyz_host
xyz_host:
- FETCHING DATA
[agent] Not using cache (Don’t try it)
[agent] Execute data source
[agent] Calling external program u’~/local/share/scripts/load_passive.sh ~/local/share/passive_checks/xyz_host.check’
[agent] Write data to cache file /omd/sites/operations/tmp/check_mk/cache/xyz_host
[agent] No persisted sections loaded
[piggyback] No persisted sections loaded- EXECUTING INVENTORY PLUGINS
File “/omd/sites/operations/bin/cmk”, line 96, in
exit_status = modes.call(o, a, opts, args)
File “/omd/sites/operations/lib/python/cmk_base/modes/init.py”, line 80, in call
return mode.handler_function(*handler_args)
File “/omd/sites/operations/lib/python/cmk_base/modes/check_mk.py”, line 1450, in mode_discover
options[“discover”] == 1)
File “/omd/sites/operations/lib/python/cmk_base/discovery.py”, line 124, in do_discovery
_do_discovery_for(hostname, ipaddress, sources, multi_host_sections, check_plugin_names, only_new, on_error)
File “/omd/sites/operations/lib/python/cmk_base/discovery.py”, line 151, in _do_discovery_for
new_items = _discover_services(hostname, ipaddress, sources, multi_host_sections, on_error=on_error)
File “/omd/sites/operations/lib/python/cmk_base/discovery.py”, line 687, in _discover_services
for item, paramstring in _execute_discovery(multi_host_sections, hostname, ipaddress, check_plugin_name, on_error):
File “/omd/sites/operations/lib/python/cmk_base/discovery.py”, line 909, in _execute_discovery
discovered_items = discovery_function(section_content)
File “/omd/sites/operations/share/check_mk/checks/mem”, line 418, in inventory_mem_used
meminfo = parse_proc_meminfo(info)
File “/omd/sites/operations/share/check_mk/checks/mem”, line 411, in parse_proc_meminfo
return dict([ (i[0][:-1], int(i[1])) for i in info ])
ValueError: invalid literal for int() with base 10: ‘119499.73’
I’m kinda lost here. Did someone go through this? How can I solve it?
