When I try to generate a combined graph from Grafana, I receive the following response:
“Checkmk exception: Currently not supported with this Checkmk Edition”
The Check_MK Edition is 2.0.0p15 (CRE).
Do you have the most recent version of the Grafana plugin installed?
Yes, but I found the issue: Check_mk raw edition not supports combined graph
If you are using Checkmk for private purposes, maybe the free edition is something you want to look at?
Alternatively you might want to look at sending your metrics to InfluxDB and use that as a data source in Grafana.
This is my preferred solution. It’s a good idea to send the stats via Telegraf, so that tags, measurements and fields can be defined and therefore the data be stored in a more logical and efficient manner.
Oh, I overlooked that you are on CRE. With CEE or CME you could send the metrics natively from Checkmk using the micro core. With the RAW edition you need to get creative, but I see you got that covered @pn-rallen.
Thank you all for the suggestions
