Hi, i just did an update from 2020.01.10.cee to 2020.03.31.cee with many warning comming from #10601 - Auto migration of check plugins to new section definitions:
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_connections
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_fan
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_firewall
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_ha_problems
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_ha_status
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_memory
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_packets
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_powersupply
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_svn_status
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_temp
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_tunnels
WARNING: Failed to auto-migrate legacy plugin to section: checkpoint_voltage
WARNING: Failed to auto-migrate legacy plugin to section: cisco_mem_asa
WARNING: Failed to auto-migrate legacy plugin to section: cisco_mem_asa64
WARNING: Failed to auto-migrate legacy plugin to section: emc_ecs_cpu_util
WARNING: Failed to auto-migrate legacy plugin to section: emc_ecs_diskio
WARNING: Failed to auto-migrate legacy plugin to section: emc_ecs_mem
WARNING: Failed to auto-migrate legacy plugin to section: f5_bigip_cluster
WARNING: Failed to auto-migrate legacy plugin to section: f5_bigip_cluster_status
WARNING: Failed to auto-migrate legacy plugin to section: f5_bigip_cluster_status.v11_2
WARNING: Failed to auto-migrate legacy plugin to section: f5_bigip_cluster_status_v11_2
WARNING: Failed to auto-migrate legacy plugin to section: f5_bigip_cluster_v11
WARNING: Failed to auto-migrate legacy plugin to section: f5_bigip_vcmpfailover
WARNING: Failed to auto-migrate legacy plugin to section: f5_bigip_vcmpguests
WARNING: Failed to auto-migrate legacy plugin to section: hr_mem
WARNING: Failed to auto-migrate legacy plugin to section: if
WARNING: Failed to auto-migrate legacy plugin to section: if64
WARNING: Failed to auto-migrate legacy plugin to section: if64adm
WARNING: Failed to auto-migrate legacy plugin to section: if_brocade
WARNING: Failed to auto-migrate legacy plugin to section: if_lancom
WARNING: Failed to auto-migrate legacy plugin to section: printer_pages
WARNING: Failed to auto-migrate legacy plugin to section: ucd_mem
Because i started with a fresh site with version 2020.01.10.cee as wrote before - are all these builtin not customer developed plugins checks removed or replaced?
Second issue during agent install or update:
Warning/Error from rpm:
file /etc/xinetd.d from install of check-mk-agent-2020.03.31-c0dfbd5bc2a52d59.noarch conflicts with file from package filesystem-3.2-25.el7.x86_64
file /etc/prelink.conf.d from install of check-mk-agent-2020.03.31-c0dfbd5bc2a52d59.noarch conflicts with file from package nss-softokn-freebl-3.44.0-8.el7_7.x86_64
file /etc/prelink.conf.d from install of check-mk-agent-2020.03.31-c0dfbd5bc2a52d59.noarch conflicts with file from package fipscheck-lib-1.4.1-6.el7.x86_64
file /etc/systemd from install of check-mk-agent-2020.03.31-c0dfbd5bc2a52d59.noarch conflicts with file from package systemd-219-67.el7_7.3.x86_64
file /etc/systemd/system from install of check-mk-agent-2020.03.31-c0dfbd5bc2a52d59.noarch conflicts with file from package systemd-219-67.el7_7.3.x86_64
It starts with the generic package, which i then installed by rpm command (rpm -i --replacefiles … ), but it persists and prevents cmk-update-agent updating installed package by baked new ones.
I would be very grateful for helpful tips or suggestions for solutions. I hope for a quick error correction in the code in one of the next daily builts.
Regards, Helge
