Hi checkers,
i have a docker based 1.6.0p8 environment for a little bit monitoring some devices at my home network. Of course the linux host self where docker besides should be monitored. Everything is fine except the logwatch configuration.
At /usr/lib/check_mk_agent/plugins there is the mk_logwatch script and if i execute this as root from the shell all log files which are defined in logwatch.cfg where discovered and with the flag “-d -v” i see that all of the exceptions they are defined at logwatch.cfg. IMHO everything fine. All other plugins in the same directory like mk_apt etc works well.
But if i set a discovery of my linux host the will not see logwatch files as services. How can i debug this?
Regards, Ralfi
