I am having check_mk raw version 1.5.0.p21. I am getting Warning alert for Check_mk Discovery as “WAYS TO CALL:” check_mk is is working fine able to get monitoring data.
Only facing issue with Discovery. Please help me to sort out this issue.
It is completed successfully. but still getting Warning alert in “Check_mk discovery”
Please refer below output.
FETCHING DATA
[snmp] Not using cache (Don’t try it)
[snmp] Execute data source
SNMP scan:
[snmp] Using persisted section ‘juniper_cpu_util’
[snmp] Using persisted section ‘snmp_info’
[piggyback] No persisted sections loaded
OK - no unmonitored services found, no vanished services found
This means the cfg files was manually edited and could not be updated from the CMK update.
But you should have an message while you updated the system the last time.
