gera83
(Gerardo)
August 15, 2017, 9:28pm
1
Hi guys.
Site: banlan
I did a:
omd stop
omd mv banlan prod
omd start prod
Everything OK.
Now, /omd/sites/prod/var/log/rrdcached.log
I have thousands of errors like:
handle_request_update: stat (/opt/omd/sites/banlan/var/pnp4nagios/perfdata/ServerX/Interface_19_in.rrd) failed
It mentions the prior site name.
Can you tell me how to fix that?
Thanks!
gera83
(Gerardo)
August 15, 2017, 9:55pm
2
Hi guys.
I found that the CORRECT METHOD (the one that works) is to do
the following:
omd stop
omd cp banlan
prod
omd rm banlan
omd start prod
Can you
confirm?
But i
cannot do that right now. It’s to late. I need a fix for my current situation!!
Any ideas?
Thanks!
---------- Forwarded message ----------
Date: 2017-08-15 18:28 GMT-03:00
Subject: CRE1.2.6p10 --site rename issue
To: “checkmk-en@lists.mathias-kettner.de ” checkmk-en@lists.mathias-kettner.de
Hi guys.
Site: banlan
I did a:
omd stop
omd mv banlan prod
omd start prod
Everything OK.
Thanks!
The reason for the rrdcachelog errors is the cache file from rrdcached. After moving and starting the site rrdcached tries to replay the log files and produces the errors. If I move a site I remove this cache files or flush the rrdcached before I move the site.
Now you can only ignore this errors.
br
Andreas
On Di., 15. Aug. 2017, 23:56 Gerardo Ferreyra raptorg83@gmail.com wrote:
Hi guys.
the following:
omd stop
omd cp banlan
prod
omd rm banlan
omd start prod
Can you
confirm?
But i
Any ideas?
Thanks!
Hi guys.
Site: banlan
I did a:
omd stop
omd mv banlan prod
omd start prod
Everything OK.
Thanks!
checkmk-en mailing list
gera83
(Gerardo)
August 16, 2017, 4:11pm
4
Andreas, 2 things:
Suppose i need to move a host to another site:
It is totally safe to move ~/var/pnp4nagios/perfdata/HOST/* to a new site, in order to keep OLD performance data? I guess im doing something wrong, because perfdata stops working. I don’t see old and new. Just for that host.
You are telling me i should remove cache files or/and flush rrdcached.
By cache files, you mean to delete ~/tmp/check_mk/cache/HOST ?
Then, what you mean by flush rrdcached? How?
Thanks!
2017-08-16 3:14 GMT-03:00 Andreas Döhler andreas.doehler@gmail.com :
br
Andreas
Hi guys.
the following:
omd stop
omd cp banlan
prod
omd rm banlan
omd start prod
Can you
confirm?
But i
Any ideas?
Thanks!
Hi guys.
Site: banlan
I did a:
omd stop
omd mv banlan prod
omd start prod
Everything OK.
Thanks!
