I have a question about if it is possible monitor files, this is the situation, i have a file in the path tmp/file.hprof and i need to know if the file exist in some hosts, so i dont know if there is a way to create a rule that allow to us verify if a file exists in some path. I don’t need to review the information included in the file, just to know if the file exists or not.
You can use the normal “fileinfo” for such a monitoring.
On the CMK site you then define a grouping pattern for your file and then you assign a ruleset to this group that you get an alarm if this group has more than 0 files.
