From debug: no notification will be sent
I’ll havw to test this for myself…
sent from my SGS3
Am 06.08.2013 12:20 schrieb “Presidio TI DLCI” presidio.ti.dlci@interno.it:
I'm so stupid! I didn't noticed that line on the global settings. I
believed that the config for email should have be done from nagios
config files. Anyway I’ve changed the command in “/usr/sbin/sendmail
-vt $CONTACTEMAIL$”, but I still can’t receive email. Making the
test I’ve the following in the debug:<small> [1375784181.309122] [032.0] [pid=14943] ** Host Notification
Attempt ** Host: ‘capua1’, Type: 0, Options: 0, Current State: 1,
Last Notification: Mon Aug 5 17:31:06 2013[1375784181.309276] [032.1] [pid=14943] We shouldn't re-notify
contacts about this host problem.
[1375784181.309308] [032.0] [pid=14943] Notification viability
test failed. No notification will be sent out.
[1375784181.309351] [032.0] [pid=14943] ** Service Notification
Attempt ** Host: ‘capua1’, Service: ‘Check_MK’, Type: 0, Options:
0, Current State: 2, Last Notification: Thu Jan 1 01:00:00 1970[1375784181.309391] [032.1] [pid=14943] The host is either down or
unreachable, so we won’t notify contacts about this service.
[1375784181.309421] [032.0] [pid=14943] Notification viability
[1375784181.336258] [032.0] [pid=14943] ** Service Notification
Attempt ** Host: ‘capua1’, Service: ‘Check_MK’, Type: 99, Options:
0, Current State: 2, Last Notification: Thu Jan 1 01:00:00 1970[1375784181.336331] [032.0] [pid=14943] Notification viability
test passed.
[1375784181.336361] [032.1] [pid=14943] Current notification
number: 0 (unchanged)
[1375784181.336393] [032.1] [pid=14943] Service notification will
NOT be escalated.
[1375784181.336427] [032.1] [pid=14943] Adding normal contacts for
service to notification list.
[1375784182.135587] [032.0] [pid=14943] 1 contacts were notified.</small> Il 06/08/2013 11:57, Marcel Schulte ha
scritto:
So the problem changed, the initial one is solved.
Goog news!
You can check the used command in WATO -> Global
settings → Notifications.
Try to execute that command as the user nagios runs as. Maybe
permissions must be chamged or similar.
sent from my SGS3
Am 06.08.2013 11:49 schrieb "Presidio TI > > DLCI" <presidio.ti.dlci@interno.it>:
This is the
notification log:
<small> [1375782449.105267] [032.0] [pid=893] ** Host
Notification Attempt ** Host: ‘capua1’, Type: 0, Options:
0, Current State: 1, Last Notification: Mon Aug 5
17:31:06 2013[1375782449.105373] [032.1] [pid=893] We shouldn't
re-notify contacts about this host problem.
[1375782449.105406] [032.0] [pid=893] Notification
viability test failed. No notification will be sent out.
[1375782449.292236] [032.0] [pid=893] ** Host Notification
Attempt ** Host: ‘capua1’, Type: 99, Options: 0, Current
State: 1, Last Notification: Mon Aug 5 17:31:06 2013[1375782449.292311] [032.0] [pid=893] Notification
viability test passed.
[1375782449.292342] [032.1] [pid=893] Current notification
number: 1 (unchanged)
[1375782449.292373] [032.1] [pid=893] Host notification
will NOT be escalated.
[1375782449.292402] [032.1] [pid=893] Adding normal
contacts for host to notification list.
[1375782450.469510] [032.0] [pid=893] 1 contacts were
notified.
This is messages: <small> Aug 6 11:47:29 netmonitor4 nagios: EXTERNAL COMMAND:
SEND_CUSTOM_HOST_NOTIFICATION;capua1;0;nagiosadmin;TEST
Aug 6 11:47:29 netmonitor4 nagios: HOST NOTIFICATION:
nagiosadmin;capua1;CUSTOM (DOWN);check-mk-notify;CRITICAL
172.25.3.252 : rta nan, lost
100%;nagiosadminBut I haven't received the email, does the check_mk plugin
use comman “mail” or “sendmail”? I’ve only the second.
Il 06/08/2013 11:42, Marcel Schulte ha scritto:
Thanks. Hoped to see empty Host contactgroups ;-) Did you try to send test notification after last changes? What does the debug log (for notifications) say? At the beginning it said "no contacts found for host"). 2013/8/6 Presidio TI DLCI <presidio.ti.dlci@interno.it>:
Ah ok! Sorry! Il 06/08/2013 11:28, Marcel Schulte ha scritto:
OK, maybe I wasn't specific enough (because that's the preferences page again)... Open this URL and send a shot: http(s)://<url_to_you_multisite_ui>/view.py?host=capua1&view_name=hoststatus 2013/8/6 Presidio TI DLCI <presidio.ti.dlci@interno.it>:
Marcel I've sent it in a previous email, here you are in attachment Il 06/08/2013 10:57, Marcel Schulte ha scritto:
One more. ;-) I'm still waiting for the host's detail page... 2013/8/6 Marcel Schulte <schulte.marcel@gmail.com>:
Did you do that here: WATO -> Host and service parameters -> Grouping -> Assignment of hosts to contact groups or here: WATO -> Host and service parameters -> Grouping -> Assignment of services to contact groups? Your screenshot shows the rule of the second possibility - but that's wrong, the first one would be right. Don't forget to apply changes... 2013/8/6 Presidio TI DLCI <presidio.ti.dlci@interno.it>:
I've created the rule in grouping menu only for host like you suggested, but nothing. what command the notification plugin use? The one specified in the nagios config file (commands.cfg), associated in contact.cfg to the user? Or it has its own? Il 06/08/2013 10:43, Marcel Schulte ha scritto:
As mentioned: create your rule for the host, not the host's services. 2013/8/6 Presidio TI DLCI <presidio.ti.dlci@interno.it>:
Danny, actually I've removed all filters, but I have the same problem. Il 06/08/2013 10:04, Kip, Danny (CIV) ha scritto:
It's probably nothing, but I notice you mentioned you added 'capua_1' to the contact group, but the logging excerpt says 'capua1' without underscore. If this is really the case, that would be a good explanation :) //Danny. -----Oorspronkelijk bericht----- Van: Presidio TI DLCI [mailto:presidio.ti.dlci@interno.it] Verzonden: maandag 5 augustus 2013 12:42 Aan: checkmk-en@lists.mathias-kettner.de Onderwerp: [Check_mk (english)] notification trouble Hi, I have a problem with check_mk notification. I followed the wiki ([http://mathias-kettner.de/checkmk_flexible_notifications.html](http://mathias-kettner.de/checkmk_flexible_notifications.html) ) an I have the attempted string in /var/log/messages after clicking the test button. Manually using sendmail messages are delivered. From debug I have the following text: [1375698038.168104] [032.0] [pid=15374] Notification viability test passed. [1375698038.168132] [032.1] [pid=15374] Current notification number: 1 (incremented) [1375698038.168162] [032.1] [pid=15374] Host notification will NOT be escalated. [1375698038.168189] [032.1] [pid=15374] Adding normal contacts for host to notification list. [1375698038.168223] [032.0] [pid=15374] No contacts were found for notification purposes. No notification was sent out. [1375698038.168266] [032.0] [pid=15374] ** Service Notification Attempt ** Host: 'capua1', Service: 'Check_MK', Type: 0, Options: 0, Current State: 2, Last Notification: Thu Jan 1 01:00:00 1970 The host capua_1 has been added properly to contact group and the relative contact too. Could you help me to reso lve this problem? Thank You for your attention
_______________________________________________ checkmk-en mailing list checkmk-en@lists.mathias-kettner.de [http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en](http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en)
