I can’t get perf-o-meter to work with custom local checks. There is no instruction on the document on how to do this. What command name should I use to register local checks? Are this function even allowed for local checks and MRPE checks?
thanks,
Henry
Existing perfometers are in the files in
/omd/versions/[version]/share/check_mk/web/plugins/perfometer and
you should be able to drop additions into the folder
/omd/sites/[site]/local/share/check_mk/web/plugins/perfometer. You
simply need to define a function to render the perfometer in HTML
and then append it to the ‘perfometers’ dict. You can also re-use
existing perfometers if your data is structured similarly.
eg. For a custom check I created called 'df_inodes' my script in the
perfometers folder is simply:
perfometers["check_mk-df_inodes"] = perfometer_check_mk_df
On 2013-12-10 1:03 AM, Henry Huang
wrote:
I
thanks,
Henry
checkmk-en mailing list
-- Wade Rossmann
Systems Administrator
checkmk-en@lists.mathias-kettner.dehttp://lists.mathias-kettner.de/mailman/listinfo/checkmk-enrossmann.wade@realestatewebmasters.com
Hi Wade,
I have read the documentation and understand the locations and things to put in the script. I have created custom script that sits in the target node under
/usr/lib/check_mk_agent/local/freeswitch
the output of the check looks like this
0 Call_Count count=200;;500;0;1000 200 live calls, Call counts looks good.
0 Calls_Per_Second cps=0;15;20;0;30 0 calls per second
What would be the name of the check that I use for perf-o-meter. I have tried to use “Call_Count”, “check_mk-local”, “check_mk-Call_Count” as names, but none of them shows a perf-o-meter for me.
Thanks,
Henry
On Tue, Dec 10, 2013 at 9:43 AM, Wade Rossmann rossmann.wade@realestatewebmasters.com wrote:
wrote:
I
thanks,
Henry
-- Wade Rossmann
Hi Henry,
firstly said: I neither did test this myself nor use local checks.
The command name should be "check_mk-local" as this is the command for
all local checks (all local checks will get the same perfometer).
Did you restart the webserver ("omd restart apache" if using OMD)
after changing the command name in perfometer config?
Regards,
Marcel
2013/12/10 Henry Huang <red.rain.seven@gmail.com>:
Hi Wade,
under
<<<local>>>
tried to use "Call_Count", "check_mk-local", "check_mk-Call_Count" as names,
Thanks,
Henry
On Tue, Dec 10, 2013 at 9:43 AM, Wade Rossmann > <rossmann.wade@realestatewebmasters.com> wrote:
/omd/versions/[version]/share/check_mk/web/plugins/perfometer and you should
/omd/sites/[site]/local/share/check_mk/web/plugins/perfometer. You simply
need to define a function to render the perfometer in HTML and then append
it to the 'perfometers' dict. You can also re-use existing perfometers if
On 2013-12-10 1:03 AM, Henry Huang wrote:
I can't get perf-o-meter to work with custom local checks. There is no
thanks,
Henry
Wade Rossmann
Unfortunately I’m not intimately familiar with local checks, but I’d
imagine investigating how the perfometer gets to the page would be
the way to go. I’ve gotten as far as paint_perfometer() in
web/plugins/views/perfometer.py
I can’t find anywhere where that’s actually called, but I imagine
that if you were to capture the ‘row’ parameter, and the subsequent
parsing to ‘check_command’ that should be the name you want to give
your perfometer.
http://git.mathias-kettner.de/git/?p=check_mk.git;a=blob;f=web/plugins/views/perfometer.py#l122
On 2013-12-10 10:25 AM, Henry Huang
wrote:
Hi
Wade,
I
the
0 Call_Count
good.
0 Calls_Per_Second
Thanks,
Henry
are in the files in
and you should be able to drop additions into the folder
You simply need to define a function to render the
perfometer in HTML and then append it to the ‘perfometers’
dict. You can also re-use existing perfometers if your
script in the perfometers folder is simply:
I
thanks,
Henry
-- Wade Rossmann
-- Wade Rossmann
Alright, I got it all figured out. Solved (thanks again Marcel)
Here’s what happened. In my earlier tests, I have tried to use “check_mk-local” as the perf-o-meter name and I also restarted apache using this command “service apache2 restart” and no perf-o-meter will show up for my local script. I had to use “omd restart site apache” instead like Marcel instructed, then viola~ the perf-o-meter shows. I am going to make it easy for everyone here.
Follow the official perf-o-meter document on defining your template
If you want to use perf-o-meter for local checks, use this command name for perf-o-meter
perfometers[“check_mk-local”] = perfometer_your_custom_template_name
Or if you want to put MRPE checks on perf-o-meter, use the actual command name that is executed in the /etc/check_mk/mrpe.cfg , here we will use “check_mysql_health” as an example
perfometers[“check_mysql_health”] = perfometer_your_custom_template_name
- After you are done with the changes, restart apache for your monitoring instance if you are using OMD
omd restart sitename apache
- Check on Multisite, refresh your page, you should now see the perf-o-meter showing up
The downside for check_mk-local is that no matter how many different script you have, they all have to share one perf-o-meter template under the same “check_mk-local” command name. I hope this can be addressed in the future check_mk or OMD release. Same goes for MRPE checks, the same command name will be used for many different output, some are counts, some are percentage, it will be hard to display them all using perf-o-meter under one template.
Other than that, I am a happy camper to see some nice perf-o-meter for my custom scripts.
Henry
On Tue, Dec 10, 2013 at 10:50 AM, Marcel Schulte schulte.marcel@gmail.com wrote:
Hi Henry,
The command name should be “check_mk-local” as this is the command for
Did you restart the webserver (“omd restart apache” if using OMD)
Regards,
Marcel
2013/12/10 Henry Huang red.rain.seven@gmail.com:
Hi Wade,
under
Thanks,
Henry
it to the ‘perfometers’ dict. You can also re-use existing perfometers if
eg. For a custom check I created called ‘df_inodes’ my script in the
thanks,
Henry
Wade Rossmann
