wir ziehen aktuell langsam von nagios auf check_mk um. Dabei haben wir im nagios noch cacti und weathermap laufen. Gibts es eine möglichkeit check_mk auch mit beiden zu nutzten oder eine alternative?
MfG
Schuby
MfG
Schuby
The question is what do you do with booth tools.
If you used Cacti for graphing then this is already included in CMK and you don’t need any extra software.
The weathermap function depends on your old system. The included NagVis can generate weathermap lines for traffic.
tyvm. Its exactly what i searched for!
I used this for the very first steps: https://www.youtube.com/watch?v=f66USWkNRJk
After i added the first traffic line i am getting an error that makes the map unusable anymore:
Javascript error occured: TypeError: output.match(…) is null /check_mk/nagvis/frontend/nagvis-js/js/NagVisCompressed.js?v=1.9.20 (3578)
In the top it keep saying “Loading…” and the traffic line is not shown.
Anything i am doing wrong here?
You guys are awesome quick! I love the forum thaaanks!!!
