Which value is to be modified to rectify checkmk checker usage which is in warning state
You can configure these parameters under Global Settings:
Setup - General - Global Settings - Monitoring Core - Maximum concurrent Checkmk checkers
If your monitoring instance is nearing its capacity, check out the official performance-tuning guide:
https://checkmk.atlassian.net/wiki/spaces/KB/pages/9473747/How-to+adjust+Checkmk+performance
TL;DR:
If you can’t add more checkers (or cores), consider scaling out with a distributed setup:
