Checkmk 2.0.0p2 - Graphs not loading
Hello.
Recently I installed latest RAW Version from scratch on Debian 10 latest build. Did all exactly as described in the installation manual.
I added a simple Windows host, monitored by the latest agent, discovery worked, services got created but I do not have all graphs available. It only shows graphs for memory usage, uptime and the check agent. But no graphs for hdd utilization or network adapters.
Can anybody give me a hint what’s wrong here? Is it a licensing issue?
Regards,
Andreas
will be fixed with werk #12298
Thanks for your quick response. When do you think the new p3 will be released?
Quickfix is described here
Hi Andreas!
Thanks for the hint, the workaround did the trick, now the graphs are showing flawlessly.
Thank you again for your quick response,
Greetings from upper Frankonia,
Andreas
