CMK version:
2.0.0p20 CRE OS version:
Debian 10.12 Error message:
None Output of “cmk --debug -vvn hostname”: (If it is a problem with checks or plugins)
We have.a Juniper qfx10002-72q switch with 4 power supplies, numbered 0 to 3. Power supply number 3 has failed, and checkmk didn’t notice. When I look in checkmk at the services for the switch, checkmk shows that it has discovered power supplies 0 and 1, but doesn’t know about 2 and 3.
This information is important for troubleshooting, as inside the check is defined what data should be fetched from the device.
Inside the Juniper list of checks is only the “juniper_trpz_power” and “juniper_fru” i think relevant for PSUs.
Can you please provide the output of an SNMPwalk on the OID “.1.3.6.1.4.1.14525.4.8.1.1.13.1.2.1” or “.1.3.6.1.4.1.2636.3.1.15.1”
I think the second one is the only working on your device.
