Checkmk host on AWS
Hi!
I’m building a monitoring site on AWS to monitor hosts on AWS, Internet and also on prem via VPN. The idea is to have a dashboard site and N monitoring sites. I was planning to expose the portal through an ALB but was wondering which was the best solution for agent registration ports as I guess exposing them via ALB is not possible because of TLS certificates.
Which would be the best solution? NLB? Exposing directly? Any experiences or insights are really appreciated!
Regards,
Alejandro
Use CLB.It just works! Just kidding :slight_smile:
You could use one NLB as the endpoint.
  • TCP 443 > Checkmk TCP 443: end-to-end HTTPS for GUI, native Checkmk SAML, REST API/agent port discovery, and distributed configuration synchronization.
  • TCP 8000 > Checkmk TCP 8000: Agent Receiver registration and Checkmk-managed mTLS. This traffic is TLS.
  • TCP 6557 > Checkmk TCP 6557, restricted to the central site/VPN, if distributed monitoring needs data through Livestatus.
Also, use TCP pass-through, with the HTTPS certificate installed on the Checkmk server. This preserves SAML and Checkmk’s TLS handling. AFAIK, an ALB cannot handle port 8000, and an ALB+NLB combination is unnecessary for a single backend site.
