CMK version:
2.0.0p17 (CME)
OS version:
ubuntu LTS 20.0.4.3
Internal error: Your request timed out after 110 seconds. This issue may be related to a local configuration problem or a request which works with a too large number of objects. But if you think this issue is a bug, please send a crash report.
File "/omd/sites/monitoring/lib/python3/cmk/gui/wato/pages/sites.py", line 602, in _action_login
secret = watolib.do_site_login(login_id, name, passwd)
File "/omd/sites/monitoring/lib/python3/cmk/gui/watolib/automations.py", line 368, in do_site_login
response = get_url(url, site.get('insecure', False), auth=(name, password),
File "/omd/sites/monitoring/lib/python3/cmk/gui/watolib/automations.py", line 341, in get_url
return get_url_raw(url, insecure, auth, data, files, timeout).text
File "/omd/sites/monitoring/lib/python3/cmk/gui/watolib/automations.py", line 313, in get_url_raw
response = requests.post(
File "/omd/sites/monitoring/lib/python3/requests/api.py", line 117, in post
return request('post', url, data=data, json=json, **kwargs)
File "/omd/sites/monitoring/lib/python3/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/omd/sites/monitoring/lib/python3/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/omd/sites/monitoring/lib/python3/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/omd/sites/monitoring/lib/python3/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/omd/sites/monitoring/lib/python3/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/omd/sites/monitoring/lib/python3/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/omd/sites/monitoring/lib/python3/urllib3/connection.py", line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/omd/sites/monitoring/lib/python3.8/http/client.py", line 1255, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/omd/sites/monitoring/lib/python3.8/http/client.py", line 1301, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/omd/sites/monitoring/lib/python3.8/http/client.py", line 1250, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/omd/sites/monitoring/lib/python3.8/http/client.py", line 1010, in _send_output
self.send(msg)
File "/omd/sites/monitoring/lib/python3.8/http/client.py", line 950, in send
self.connect()
File "/omd/sites/monitoring/lib/python3/urllib3/connection.py", line 205, in connect
conn = self._new_conn()
File "/omd/sites/monitoring/lib/python3/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/omd/sites/monitoring/lib/python3/urllib3/util/connection.py", line 86, in create_connection
sock.connect(sa)
File "/omd/sites/monitoring/lib/python3/cmk/gui/utils/timeout_manager.py", line 35, in handle_request_timeout
raise RequestTimeout(
cmk.gui.exceptions.RequestTimeout: Your request timed out after 110 seconds. This issue may be related to a local configuration problem or a request which works with a too large number of objects. But if you think this issue is a bug, please send a crash report.
Description/extra info:
We’re using Checkmk in a multisite setup, all sites are connected in a star-based VPN setup.
This specific site is SNAT’ted from the new site’s end (so 192.168.x.x to 172.16.x.x for traffic going to the checkmk master site ).
We get a timeout, first time I’m experiencing this. Other traffic between sites works well.
Brand new site/virtual server on new site.
Where can I search for more?
Thanks in advance!
Thomas
