I have problem with showing data output from my Classical active and passive Monitoring checks
check_snmp -H xxxxx -C xxxx -P 2c -o .1.3.6.1.4.1.12148.9.4.1.0 | awk ‘{printf "%d\n ",p=$4}’
from this command in services tab i have output (null) but
When i check this by WATO-CONFIGURATION > hosts > edit the services of this host, do a services discovery i have good output.
I will add that the Installed / Active Rectifier rule is almost the same as TotalDC and also uses awk
The difference between the two rules is that in this inoperative, the values change faster over time
awk is for changing output data from check_snmp
check_snmp -H 10.42.190.130 -C cdscomm -P 2c -o .1.3.6.1.4.1.12148.9.4.1.0 Output of check plugin “SNMP OK - 711”
with this
check_snmp -H 10.42.190.130 -C cdscomm -P 2c -o .1.3.6.1.4.1.12148.9.4.1.0 | awk ‘{print $4}’ output is bad only in Services view in hosts > edit the services of this host, do a services discovery i have good output.
In linux shell this command also working fine
