Is it possible to use Azure AD for authentication for Checkmk or in other words sync all the users from Azure AD inside Checkmk ?
Hi David,
As I understand it, and have just gone through.
IF you purely have hosted AzureAD ( ie no onprem ) then you will need to standup / add ldap(s) to make it work.
The native AzureAD is a greatly stripped down beast, compared to full AD.
Once I had the ldap(s) setup, it was real simple.
Thanks,
Sean.
Thanks @Approyocto for your comment. My company decided to use SAML so I have to now work on that.
