mstyx
September 7, 2022, 10:14am
1
CMK version:
2.1.0p6_0
OS version:
Debian Bullseye (11)
ERR_SSL_PROTOCOL_ERROR
Don’t work for me… Bash tells me: “command not found”
Hello Community,
i will secure my chkmk Login. I go straight to: chkmk https manual
*Yes i import my .CER File… without errors
And after a HTTPS Setup from the ChkMK Manual, my Web GUI is gone…
I do this:
And get the Answer:
user@chkmk:~$ curl -v -I https://IP_CHKMK/MYSIDE/check_mk/login.py
Trying IP_CHKMK:443…
Connected to IP_CHKMK (IP_CHKMK) port 443 (#0 )
ALPN, offering h2
ALPN, offering http/1.1
successfully set certificate verify locations:
CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
TLSv1.3 (OUT), TLS handshake, Client hello (1):
error:1408F10B:SSL routines:ssl3_get_record:wrong version number
Closing connection 0
curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number
In my opinion, the file is still missing: *.key ??
Or what am I missing? What am I doing wrong?
MarcK
September 7, 2022, 10:46am
2
Did you do a “su - SITENAME” ??
I get a commad not found when i am not switched to a site…
gstolz
September 7, 2022, 10:53am
3
Apache itself is completely happy with the config and cert + key files?
If you restart apache with “systemctl restart apache” and check “systemctl status apache” do you see anything out of the normal?
what do you mean with:
“In my opinion, the file is still missing: *.key ??”
why do you think that?
MarcK
September 7, 2022, 10:56am
4
Try to open the main web server homepage in a browser with https.
If that is working, you can switch CMK to https.
And yes, you will need cert and key for the Apache.
mstyx
September 7, 2022, 11:08am
5
Thanks for fast reply
What do you mean with: su - SITENAME ? (i have do all commands with SUDO )
Hint: chkMK is the “one and only” Service of this Apache2 Setup
By the way, i’m new at chkMK
mstyx
September 7, 2022, 11:13am
6
SSL Labs Doku tell’s:
Take the stress out of SSL installation and let our tech experts take care of it! After your Certificate is issued by the Certificate Authority, you’re ready to begin installation on your Apache server. Note: Sometimes, the “Permission Denied” error...
Est. reading time: 4 minutes
SSLCertificateFile pointed to the location of the Certificate issued for your domain name
SSLCertificateKeyFile pointed to the location of your Private Key on the server.
therefore my question, it could be that it is different here
MarcK
September 7, 2022, 11:16am
7
For the " cmk --debug -vvn hostname " command, you have to be the site-user.
That is done with su - YOURSITENAME
mstyx
September 7, 2022, 11:18am
8
JUP! i need a *.key file…
Thanks, i will generate it, and “do it again” and report here again
MarcK
September 7, 2022, 11:20am
9
Securing the web interface with HTTPS
Point 1 -3 * The server is reachable under HTTPS.
mstyx
September 7, 2022, 12:45pm
10
or, a “new” error msg
after doing point 1-3 , i use the curl command… with HTTPS =>
then i read some article about my erreor msg on stackoverflow (1) my Vhost File looks like:
<VirtualHost *:80 *:443>
i do the same curl command for chkmk without the HTTPS - HTTP only, and i see:
HTTP/1.1 302 Found
Date: Wed, 07 Sep 2022 12:29:47 GMT
Server: Apache/2.4.54 (Debian)
Strict-Transport-Security: max-age=3153600
Content-Type: text/html; charset=iso-8859-1
Sadly, no Browser will show me the chkmk login Page
Firefox: SSL_ERROR_RX_RECORD_TOO_LONG
Brave (Chrom Clon) ERR_SSL_PROTOCOL_ERROR
(1)
MarcK
September 7, 2022, 1:12pm
11
Hmmm…
I have done a look into my two sites (Apache not CMK !!! )
000-default.conf → <VirtualHost *:80>
default-ssl.conf -> <VirtualHost _default_:443>
In mods-enabled/ssl.conf is this:
# The protocols to enable.
# Available values: all, SSLv3, TLSv1, TLSv1.1, TLSv1.2
# SSL v2 is no longer supported
SSLProtocol all -SSLv3
SSLv3 is excluded…
Did you enable port 443 in Apache ports.conf?!
If you are speaking German you might rather look at this article. We are still discussing some aspects of this article until it gets translated and moved to the 2.1.0 manual.
mstyx
September 8, 2022, 9:39am
13
Moinsen
german language is not a problem for me…
I have started to build according to these instructions, we have an “internal CA”.
We have “inhouse”: *.cer and *.crt - so i can skip some of it, and “pick” the rest together
the first thing I notice is that when I run: “openssl req” I get an error message. “req” (really? REQ)
Invalid command ‘reg’; type “help” for a list.
what package am i missing? so i can have “req” in debian bullseye?
req as in request, not reg (as in register or something)
mstyx
September 23, 2022, 7:33am
15
How can i “tag” this threat as “Solved” ?!
Leaving this here because it may be helpful for others in the situation.
This video helped me setup https with a self signed certificate:
https://www.youtube.com/watch?v=Q9b0F26FR20
