We are using the cisco_ip_sla plugin but we are getting wrong index. The IDs are always starting from 0 and increasing, instead to take the ID of the SLA configured. For instance in my test we have the following 2 ip sla:
ID Type Destination Stats Return Last
Code Run
*2 icmp-echo 10.0.0.20 RTT=1 OK 5 seconds ago
*38 icmp-echo 10.0.0.20 RTT=1 OK 6 seconds ago
and in check_mk I get:
If I delete for instance the ip sla 2, in check mk I will keep ip sla 0 and will keep graphing the values for the ip sla38 on the graph that previously was graphing the ip sla 2, lossing the history for sla 38 after deleting the ip sla 2.
Did someone have a fix for this plugin or an alternative one?
Thanks and best regards,
Diego
