can you do an snmpwalk on these devices, to see what state the devices are in?
The example is from an old N56K, the redundancy framework is not supported thereā¦
I would say this means the redundancy framework will also not work with these devices. So best you disable it for the N3K. For the vPC stuff there is a plugin on the exchange. This will need some changing in the detect function as it finds N9KC9336CFX2 devices only.
