Hi!
The Plugin Outputs the following and fails:
> Agent exited with code 1: Traceback (most recent call last):
File "/omd/sites/MASTER/share/check_mk/agents/special/agent_innovaphone", line 12, in <module> sys.exit(main()) File "/omd/sites/MASTER/lib/python3/cmk/special_agents/agent_innovaphone.py", line 102, in main get_pri_channel(credentials, 'PRI' + str(channel_num)) File "/omd/sites/MASTER/lib/python3/cmk/special_agents/agent_innovaphone.py", line 33, in get_pri_channel data = etree.parse(get_url(address, user, password)).getroot() File "/omd/sites/MASTER/lib/python3.8/xml/etree/ElementTree.py", line 1202, in parse tree.parse(source, parser) File "/omd/sites/MASTER/lib/python3.8/xml/etree/ElementTree.py", line 595, in parse self._root = parser._parse_whole(source) xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 1, column 0
