Kirittsu
(Kirittsu)
December 8, 2022, 1:33pm
1
CMK version: 2.1.0p17.cre
OS version: Ubuntu LTS 22.04
Error message: ERROR [cmk_agent_ctl] Something seems wrong with the agent socket (/run/check-mk-agent.socket), aborting
Output of “cmk --debug -vvn hostname”: cmk: command not found (If it is a problem with checks or plugins)
HankB
(HankB)
December 9, 2022, 6:39pm
2
I’m facing the same issue (and also running checkmk raw in a Docker container) on a X86_64 Debian Bullseye host.
Inside the container:
root@9529f647cd27:/# omd version
OMD - Open Monitoring Distribution Version 2.1.0p17.cre
root@9529f647cd27:/# omd sites
SITE VERSION COMMENTS
cmk 2.1.0p17.cre default version
root@9529f647cd27:/# omd status
Doing 'status' on site cmk:
agent-receiver: running
mkeventd: running
rrdcached: running
npcd: running
nagios: running
apache: running
redis: running
crontab: running
Overall state: running
root@9529f647cd27:/# ping acorn3
PING acorn3.localdomain (192.168.1.90) 56(84) bytes of data.
64 bytes from acorn3.localdomain (192.168.1.90): icmp_seq=1 ttl=64 time=0.058 ms
64 bytes from acorn3.localdomain (192.168.1.90): icmp_seq=2 ttl=64 time=0.046 ms
^C
--- acorn3.localdomain ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1008ms
rtt min/avg/max/mdev = 0.046/0.052/0.058/0.006 ms
On the Docker host
hbarta@acorn3:~$ ls -l /run/check-mk-agent.socket
s-w-r----- 1 cmk-agent cmk-agent 0 Dec 6 12:07 /run/check-mk-agent.socket
hbarta@acorn3:~$ docker version
Client:
Version: 20.10.5+dfsg1
API version: 1.41
Go version: go1.15.15
Git commit: 55c4c88
Built: Mon May 30 18:34:49 2022
OS/Arch: linux/amd64
Context: default
Experimental: true
Server:
Engine:
API version: 1.41 (minimum version 1.12)
Git commit: 363e9a8
Experimental: false
containerd:
Version: 1.4.13~ds1
GitCommit: 1.4.13~ds1-1~deb11u2
runc:
Version: 1.0.0~rc93+ds1
GitCommit: 1.0.0~rc93+ds1-5+deb11u2
docker-init:
Version: 0.19.0
GitCommit:
hbarta@acorn3:~$ uname -a
Linux acorn3 5.10.0-19-amd64 #1 SMP Debian 5.10.149-2 (2022-10-21) x86_64 GNU/Linux
hbarta@acorn3:~$ dpkg -l check-mk-agent
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii check-mk-agent 2.1.0p17-1 all Checkmk Agent for Linux
hbarta@acorn3:~$ systemctl status check-mk-agent-async
● check-mk-agent-async.service - Checkmk agent - Asynchronous background tasks
Loaded: loaded (/lib/systemd/system/check-mk-agent-async.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2022-12-06 12:07:25 CST; 3 days ago
Main PID: 3205472 (check_mk_agent)
Tasks: 2 (limit: 19176)
Memory: 3.6M
CPU: 6min 49.742s
CGroup: /system.slice/check-mk-agent-async.service
├─1345903 sleep 60
└─3205472 /bin/bash /usr/bin/check_mk_agent
hbarta@acorn3:~$ systemctl --version
systemd 247 (247.3-7+deb11u1)
+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified
hbarta@acorn3:~$ cmk-agent-ctl --version
cmk-agent-ctl 2.1.0p17
hbarta@acorn3:~$
Following the instructions
Att https://docs.checkmk.com/master/en/agent_linux.html?lquery=cmk_agent_ctl I find
hbarta@acorn3:~$ ss -tulpn | grep 6556
tcp LISTEN 0 4096 *:6556 *:*
hbarta@acorn3:~$
It seems that the agent is not listening on the socket. Can this be fixed? Or is the only option to run the agent in legacy mode? https://docs.checkmk.com/master/en/agent_linux_legacy.html
If I try to run the command (on the host, with checkmk in the Docker container and mapped to port 8000) I get
hbarta@acorn3:~$ sudo cmk-agent-ctl register --hostname acorn3 --server acorn3:8000 --site cmk --user cmkadmin
Attempting to register at acorn3:8000/cmk. Server certificate details:
ERROR [cmk_agent_ctl] the handshake failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:331:
Caused by:
0: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:331:
1: error:1408F10B:SSL routines:ssl3_get_record:wrong version number:ssl/record/ssl3_record.c:331:
hbarta@acorn3:~$
Any help resolving this is most welcome.
Thanks!
mkono87
(Mike K)
December 22, 2022, 2:02am
3
I believe I may have this exactly same issue. Ubuntu 20/04 running checkmk in docker. Trying to register a proxmox host and getting the same ssl errors you are.
HankB
(HankB)
January 16, 2023, 9:58pm
4
Referring to my previous post, the command ss -tulpn | grep 6556
needs to be run as root. When I originally posted this, I knew even less about Checkmk than I do now.
I’m having another go at running this in a Docker container on another host (e.g. installing on the “prod” host on my home LAN so I can shut down the test host.)
Incidentally, I never did get this working in a Docker container satisfactorily. I wound up installing in a VM instead and that seemed to work fine, albeit at the cost of some additional resources.
It looks like there were several problems mixed up here.
The initial post suggest an issue with the UNIX socket, the Checkmk agent uses internally
Then I see mentions of TLS issues
And someone threw docker in
As the initial poster never replied, can you outline your issue in a little more detail?
system
(system)
Closed
January 17, 2024, 7:58am
6
