Hey, after upgrading to 2.1.0 and trying to enable tls, I face this error trying to register the agent with cmk-agent-ctl register: Failed to discover agent receiver port from Checkmk REST API, both with http and https.
CMK version:
root@paperless-ngx:~# cmk-agent-ctl status
Version: 2.1.0
root@checkmk:~# omd sites
SITE VERSION COMMENTS
home 2.1.0.cee default version
OS version:
root@paperless-ngx:~# uname -a
Linux paperless-ngx 5.13.19-6-pve #1 SMP PVE 5.13.19-15 (Tue, 29 Mar 2022 15:59:50 +0200) x86_64 GNU/Linux
Debian
root@paperless-ngx:~# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
root@paperless-ngx:~# cmk-agent-ctl register --trust-cert -H paperless-ngx.gerhards.local -s checkmk.gerhards.local -i home -U cmkadmin
ERROR [cmk_agent_ctl] Failed to discover agent receiver port from Checkmk REST API, both with http and https.
Error with http:
Failed to discover agent receiver port from http://checkmk.gerhards.local/home/check_mk/api/1.0/domain-types/internal/actions/discover-receiver/invoke
error sending request for url (http://checkmk.gerhards.local/home/check_mk/api/1.0/domain-types/internal/actions/discover-receiver/invoke): error trying to connect: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: (self signed certificate)
Error with https:
Failed to discover agent receiver port from https://checkmk.gerhards.local/home/check_mk/api/1.0/domain-types/internal/actions/discover-receiver/invoke
error sending request for url (https://checkmk.gerhards.local/home/check_mk/api/1.0/domain-types/internal/actions/discover-receiver/invoke): error trying to connect: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: (self signed certificate)
Either import the self signed certificate on this server paperless-ngx or use the same command with port. The port can be different in your case. So, get this from “omd config show” on your CMK instance.
Thx for the quick reply, adding the port gives still the same result:
root@paperless-ngx:~# cmk-agent-ctl register --trust-cert -H paperless-ngx.gerhards.local:8000 -s checkmk.gerhards.local -i home -U cmkadmin
Error with http:
Error with https:
root@paperless-ngx:~# cmk-agent-ctl register --trust-cert -H paperless-ngx.gerhards.local:8000 -s 10.0.4.107 -i home -U cmkadmin
Error with http:
Failed to discover agent receiver port from http://10.0.4.107/home/check_mk/api/1.0/domain-types/internal/actions/discover-receiver/invoke
error sending request for url (http://10.0.4.107/home/check_mk/api/1.0/domain-types/internal/actions/discover-receiver/invoke): error trying to connect: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: (self signed certificate)
Error with https:
Failed to discover agent receiver port from https://10.0.4.107/home/check_mk/api/1.0/domain-types/internal/actions/discover-receiver/invoke
error sending request for url (https://10.0.4.107/home/check_mk/api/1.0/domain-types/internal/actions/discover-receiver/invoke): error trying to connect: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:ssl/statem/statem_clnt.c:1914: (self signed certificate)
