Thanks for the reply , let me explain you here
as per mentioned in document The agent for Linux in detail
i have installed checkmk agent check-mk-agent-1.6.0p20-1.noarch.rpm on my centos7 instance.
service xinetd with config /etc/xinetd.d/check-mk
type = UNLISTED
port = 6556
socket_type = stream
protocol = tcp
wait = no
user = root
server = /usr/bin/check_mk_agent
only_from = 127.0.0.1 10.0.20.1 10.0.20.2 172.31.25.62
log_on_success =
disable = no
mk_jolokia.py i download and put under path /usr/lib/check_mk_agent/plugins/
Below is my jolokia config, for my tomcat which are running on ajp port 1117
It looks like that there is no Jolokia running on your server.
You followed the description how to deploy the Jolokia here? https://jolokia.org/index.html
i able to solve it now, when i comment redirectPort=“1111” ,jolokia is working fine and showing in monitoring ,1111 is ssl port , i think there is some misconfiguration for ssl port ,willcheck further for this .
I don’t think so. In my use cases i don’t administer the Tomcat servers but as far as i know you only have to deploy the Jolokia war.
On this page you have all the possible configuration options. https://jolokia.org/reference/html/agents.html
Hi Team
can somebody please help .
currently i m configuring check_mk 1.6
we are running tomcat with ajp port 1117 and https port 1111 (we r not running any http port )
i just configured jolokia in my check_mk agent .
when i try to run mk_jolokia.py , getting below ERROR
